Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-07-2010, 07:41 AM
oxzk396 oxzk396 is offline
2003 Suburban Z71 4wd
Hey all, I've got a 2003 Suburban Z71. When I put it in 4 Hi, the indicator light comes on to let me know I'm in 4wd, but it's still in 2wd. It won't actually go into 4wd even though it says it's in. Any thoughts on what it could be?
Old 12-07-2010, 08:53 AM
j cAT j cAT is offline
Re: 2003 Suburban Z71 4wd
how did you determine this ?
Old 12-07-2010, 09:07 AM
Got stuck and the back wheels were spinning and the front wheels weren't doing anything...
Old 12-07-2010, 09:30 AM
with the vehicle parked engine running place the vehicle in and out of 4wd ..do you hear any clunking clicking ? do you have any service 4wd light on ? you should if this is not engaging .
when in 4wd front of vehicle off ground ,in park , is the front axle locked together as one ?
Inspect trac II transfercase fluid it should be blue ..filled to the top of the fill hole . If fluid black color you will need to repair replace the transfercase ..
Old 12-07-2010, 09:45 AM
No clunking or clicking, but I have heard a little whiny noise that sounded like it was transferring over. No service 4wd light either.
As for checking the front axle and the fluid, I'll have to check that this weekend. Thanks for the help so far!
03 Z71 4WD Service Message SilveradoZ71 Silverado 11 01-30-2010 12:18 PM
2003 suburban service 4wd light on mallardcurl Suburban 5 09-02-2009 08:30 AM
2003 suburban abs/4wd warning lamps [email protected] Suburban 6 04-30-2006 01:25 PM
2003 Chevy Suburban Z71 - 4WD Problem mn2ga Suburban 1 01-29-2005 12:23 AM
97 Z71, 4wd? sp3edr4cer Silverado 0 11-08-2004 10:02 AM
