Old 12-06-2010, 09:00 PM
schadd1971 schadd1971 is offline
no heater at idle/heat when driving
hi weird problem....when sitting the air blows cold even when engine is at normal operating temp....yet when you start driving down the road the heat starts to come out the vents the van gets cozy like normal...yet if you park and keep the van running you feel the air go cold again....and when You go again..warm again...anY ideas...
Old 12-06-2010, 09:11 PM
tempfixit tempfixit is offline
Re: no heater at idle/heat when driving
Have you added coolant lately or serviced coolant system? Is the coolant level at proper level. Make sure there is not any air in the system (burb the system).
How many miles on vehicle and is the water pump original, if so the blades on the water pump may be eroded away.
98 Durago over heating while idle, not when driving tbutler324 Durango 2 06-02-2008 07:12 PM
Low oil pressure at idle, fine when driving mixedgrip Rodeo | Passport | MU 11 12-30-2006 01:20 PM
No heat when driving dlaw Camry/Camry Hybrid/Vista 5 01-15-2005 05:35 PM
no heat when driving aurora13 Cutlass Series 7 01-05-2005 04:59 PM
