Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-22-2004, 01:37 PM
aurora13 aurora13 is offline
no heat when driving
hello i have a 1990 olds calais and it runs great i get a little heat when the car is at idle in park then when i put in drive and get going there is
no heat. does anyone know what is going on here. thank you
Old 12-22-2004, 04:19 PM
djnoname djnoname is offline
Re: no heat when driving
put a peice of carboard in front (towards headlites not cooling fan) of your radiator.
Old 12-22-2004, 07:06 PM
jmblimo's Avatar
jmblimo jmblimo is offline
Make sure there is enough coolant.
FLEETWOOD MIKE
Old 12-28-2004, 09:53 AM
Rockett30 Rockett30 is offline
10 to 1 says that your thermostat has failed open and your water pump is contantly moving the water from your block through your radiator. If the water in your block doesn't have enough time to warm up, you will not get any heat. I'd say check your thermostat.
Old 12-30-2004, 01:39 PM
86in 86in is offline
i had a 94 cutlass do the same, i was told the thermastat was stuck open, sold it before i fixed it though
Old 01-05-2005, 02:56 PM
Thought about that too but its getting heat while idling though?
Old 01-05-2005, 03:11 PM
SniperX13's Avatar
SniperX13 SniperX13 is offline
Send a message via Yahoo to SniperX13
Re: Re: no heat when driving
trust me, I bet its your thermostat. My wife's sunbird was doing the same thing, does your temp needle even move at all? I spent 6 bucks for the new part, and now she has her heater back, and especially her defroster, and the needle moves as well.
"Who are we to judge those, when we ourselves are afraid to be judged."
Old 01-05-2005, 04:59 PM
jmblimo's Avatar
"djnoname" is correct about using the cardboard to diagnose the problem. If blocking the air through the radiator corrects the problem then it 100% sure it's the thermostat. Just make sure you don't block all the air as the car will overheat.
FLEETWOOD MIKE
