Old 04-07-2003, 08:29 PM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
Exhaust smells like gas
like the title says why does my exhaust smell like gass all the time. it's a lot more pronounced in the morning, or when the engine is cold but i can smell it when it is warm. also i get pretty good gas milege 24mpg with city and highway driving. any ides on how to adjust that ?
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
Old 04-08-2003, 09:31 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
Sounds like your running way to rich. What kind of fuel pressure are your running, and what are you using to increase it with...?
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 04-08-2003, 10:05 AM
it's the stock FPR. gotta go and get one of those fuel pressure testers
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
Old 04-09-2003, 08:46 AM
Just get a B&M Fuel Pressure Set... That way you would be able have permanent pressure gauge, even tho it's under the hood. Probably save you few bucks, as compared to a testing one. hehehe
ZYDNE SECU, 450's
Old 04-11-2003, 08:07 PM
i was thinking about the aem fpr.
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
Old 04-14-2003, 06:31 AM
hondacivic4drlx's Avatar
hondacivic4drlx hondacivic4drlx is offline
Send a message via AIM to hondacivic4drlx
SOUNDS TO ME LIKE TURBO WOULD BE A PREMIEM UPGRADE RIGHT ABOUT NOW.
Old 04-14-2003, 08:08 AM
I just went ahead got a B&M CommandFlo, for a fuel presssure regulator. Never have heard to much about an AEM one tho...
ZYDNE SECU, 450's
Old 04-14-2003, 11:30 AM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
Re: Exhaust smells like gas
Do you have a check engine light on? Do you still have an 02sensor.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 04-14-2003, 11:32 AM
nope no cel, and yes i have the o2 sensor in there but i think it mught be a bit fouled because the amount of crabon in my exhaust pipe
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
