Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 12-05-2010, 01:07 AM
jeremy06 jeremy06 is offline
Send a message via Yahoo to jeremy06
engine mounts...3.3v6 intrepid
location..location...location.... I have a 1994 dodge intrepid es. Which I bought as a project. Heres the scoop...go to start, starts fine....shift into reverse... idle in reverse... no problems goes in reverse at idle/very low speed. give it a little gas... loud bang noise but goes reverse fine. shift into drive. no other problems upshift or down shift. just once you give the intrepid gas after in reverse. not while shifting.
Old 12-05-2010, 09:51 PM
urclueless urclueless is offline
Banned
Re: engine mounts...3.3v6 intrepid
you need a trans mount. I've got one cheap. $30 with shipping. 5 bolts holds it in all you need is a floor jack, jack stands, 13mm wrench and a 15mm. and about 1hr of your time.
96 Intrepid rack and pinion steering mount bushings ksroadking Intrepid 2 02-27-2014 07:39 AM
97 Intrepid 3.3 Sub Frame Bushings and Mounts Gabriel T. Intrepid 1 07-03-2010 06:13 AM
Mystique 97 - Engine Mount / Motor Mount??? shivparekh Mystique 6 12-30-2008 02:40 AM
Engine Mount Problem on V6 3.0L 1MZFE artbuc Avalon/Pronard 3 03-27-2008 02:55 PM
3.3L Intrepid Engine Interchangable? A. Souphound Intrepid 3 02-13-2005 09:19 AM
