Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 12-04-2010, 04:55 PM
___Brandon ___Brandon is offline
Ford Escape Front Drive Shaft Installation
Hello,
I took the front drive shaft out of my escape, and now I can't figure out how to get all the ball bearing in place and get the thing back together.
It has a regular U joint in the back, but the front has a constant velocity joint setup with about a half dozen ball bearings in it that all hit the floor when you take it apart.
How do I get this thing back together?????
Thanks,
Old 12-05-2010, 03:59 PM
Re: Ford Escape Front Drive Shaft Installation
I found that if you tap around the big 3" thick spacer it will come off and then the whole driveshaft assy can be hauled over to the bench and the ball bearings can be wrestled back in place. The thing really doesn't act like a slip joint though. Is it just supposed to a misalignment coupler?
2002 Ford Escape Front endproblems bg7385 Escape | Maverick | Escape Hybrid 0 07-11-2009 12:27 PM
altima drive shaft installation suren Altima 0 10-23-2005 10:18 PM
Drive shaft installation mr.death '88 - '91 Civic | CRX | Wagon | Shuttlee 3 04-05-2004 09:34 PM
front drive shaft 87 blazer slammed87 Blazer 1 02-19-2004 07:50 PM
front drive shaft aaron smith C/K 0 10-15-2003 02:57 PM
