Old 12-03-2010, 10:14 PM
20GMC00 20GMC00 is offline
2000 C 2500 Coolant in Oil
I have a 2000 GMC C 2500 4X2 with a 5.7 Vortec. It has 211,000 miles. I checked the oil in in lastnight and it was 4 inches over full and looked like it was muddy. I checked the radiator and it was about 4 inches low. I changed the oil and checked the compression and got got exactly 125 psi on all cylinders but one and it had 127. It got antifreeze in the oil just from turning it over to check the compression. Any one got any ideas where the antifreeze is coming from. Intake, head gasket, cracked oil cooler in radiator?? Thanks
Old 12-03-2010, 10:59 PM
j cAT j cAT is offline
Re: 2000 C 2500 Coolant in Oil
what did the plugs look like ? all the same color / burn ? any super white and clean ?
when the engine is running and the coolant cap off, rev engine do you get air bubbles in the coolant ..
disconnect engine oil cooler use 20 psi of air pressure test for leaks.
could be head crack. coolant with some cracks can dump into the crankcase ..this will give good compression but coolant in the oil...
Old 12-03-2010, 11:33 PM
Spark plugs all looked the same...brownish.
No bubbles in coolant when it is running.
I am gonna check the coolant tank tomorrow and let you know.
Thanks
Old 12-04-2010, 01:06 PM
Thanks
If the coolant does not bubble with exhaust pressures[place a ballon over the cap hole ] , then remove valve cover[s] and inspect for coolant leak running down into the oil drain back hole , on top of the head.
Old 12-04-2010, 02:50 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Could be intake manifold gasket.
Any external coolant leaks?
Put a pressure tester on rad and see if it holds pressure.
If leaking off and no outside leaks drain oil and leave oil plug out and pump up pressure on rad and watch for coolant running out oil drain hole.
MT
Old 12-05-2010, 10:30 AM
There are no external leaks. If the oil cooler is leaking on the side of the radiator, wouldnt there be oil in the coolant also? I looks bright green still. Havent had time to check the radiator yet.
Old 12-05-2010, 11:10 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
I agree. Sounds like a Lower Intake Manifold Gasket to me.
I would just take it apart and once the LIM is off, check the coolant ports for signs of leaks past the gasket into the lifter valley.
If the LIM gaskets are original, they are probably WAY overdue. Fel-Pro makes an aluminum framed replacement set that does a good job. Also replace the LIM bolts. Fel-pro also makes a new set of bolts that will come with the right amount of threadlocker on them.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-05-2010, 12:20 PM
Im gonna start tearing it apart one of these days when I can find some spare time. I will let you know what i find. Thanks.
Old 12-05-2010, 01:06 PM
when coolant enters the crankcase you have no time !
coolant WILL rapidly destroy the engines internal components..
Old 12-05-2010, 06:16 PM
Wonderful! Good thing I have got a few other vehicles. I did start taking it apart just to look at it. What is the big black plug for right behind the throttle body? I unplugged it and there was about 1/4 inch of gas in the bottom of it. Is it some type of of fuel regulator or something.
Old 12-06-2010, 02:23 PM
MT-2500's Avatar
AF - Advisor
Are asking about the one where about 16 injector wires plug into top of intake and where the 2 fuel lines go in?
If so just plulling plug there should be no gas in it but if you had fuel lines un pluged the gas could have come from them.
If just wire plug in pull out and there is gas the injector body wiring is leaking or the seals on fuel lines.
with fuel line pluged in prime up fuel pressure and see if any leakage there.
Post back what you find.
MT
Old 12-06-2010, 07:06 PM
I have not unhooked the fuel lines yet. Just unplugged that big plug.
Old 12-06-2010, 07:10 PM
MT-2500's Avatar
AF - Advisor
OK
Blow/clean out old gas and prime up fuel pressure and watch for any gas leakage.
If lines not leaking check for gas leakage around injector wire pins.
Let us know what you find there.
MT
Old 12-07-2010, 05:30 PM
It is coming up through the pins.
Old 12-07-2010, 06:58 PM
MT-2500's Avatar
AF - Advisor
You have a bad/leaking injector.
They can be replaced seperate if only one bad.
Try to find out which one and bend pin over so you can tell which injector it is when you take it apart.
Two pins for each injector.
If more than one injector is leaking.
I would replace all of them.
Let us know how it goes and good luck.
MT
81 Caddy with Oil in Coolant, NO Coolant in Oil! dustavo '79 - '90 5 03-24-2009 07:44 AM
2000 SS coolant mix with oil...and other things dupo24 Monte Carlo 5 04-27-2007 08:02 PM
95 2500 coolant leak coachmilliren Ram Pickup | Ram SRT10 2 05-19-2006 11:02 AM
89 525i oil in coolant, coolant in oil? Help! ShadeTreeBill 5 Series 5 02-11-2006 01:33 AM
1997 2500..coolant leak dexter2500 Ram Pickup | Ram SRT10 1 03-04-2005 04:01 AM
