Old 12-03-2010, 07:58 AM
valente valente is offline
gas cap question
I noticed 2 weeks ago that my gas cap would not tighten down,it just turns and turns.it doesnt come of if i try to pull it,it will come of if i turn it the opposite way,but if i try to tighten it up it wont tighten.do i need a new cap or im good the way it is.
thanks
Old 12-03-2010, 02:43 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: gas cap question
you may need a new cap. It has to be properly tightened, or it will trip an emissions trouble code. At first I read this wrong. I read it as saying you couldn't get it off unless you pulled on it. These caps have a ratchet cam in them to prevent them from being overtightened, so they will turn indefinitely if you don't stop.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-03-2010, 04:23 PM
so its time for a new cap.never knew about the ratchet cam,do all cars have that or just some.
can i buy a new cap at any autoparts store,or someone knows a store that i can order it online.
thank you
Old 12-03-2010, 04:38 PM
richtazz's Avatar
If you have no check engine light on, and the cap distinctly clicks as you turn it, then you shouldn't need a new one. If it doesn't click as you tighten it, or if your CEL is on, then it may be time for a new one.
Old 12-03-2010, 07:02 PM
it does click every time i try to tighten it down.before i would do like 1 or 1 1/2 turns and it would tighten down but now it just turns(and clicks every time i turn it).
no i dont have any check engine lights on.
Old 12-04-2010, 07:06 PM
BNaylor's Avatar
BNaylor BNaylor is offline
The ratcheting sound while tightening is normal for all GM gas caps. If it doesn't make the sound then you have an issue. You can remove the gas cap when turning removing/counterclockwise? Also, when you turn counterclockwise about 1/4 turn and release does the cap spring back to the right?
Timeslip 08/12/06
AF Community Guidelines
Old 12-09-2010, 12:47 PM
i dont mind the ratcheting sound,i was just woried about the cap not tighten down and have a high fuel use.
and the cap doesnt spring back after th 1/4 turn.
if its no big deal than i wont enven bother with it.
thank you for the help
Old 12-11-2010, 09:44 AM
BNaylor's Avatar
Although it doesn't appear to be causing any issues best to replace the gas cap. It is not acting properly. The gas cap should not cause high fuel consumption and if bad would give off an evaporative emissions code (DTC).
Higher fuel consumption during the winter months is normal. What is your current in city and highway mileage?
Timeslip 08/12/06
Old 12-12-2010, 08:15 PM
sorry for the late reply,but we got hammered with a bunch of snow and been shoveling all day
i just order the cap today,just to be on the safe side
thanks for the help
Can't put gas in my 06 Silverado ajdesigns Silverado 9 06-01-2010 03:16 PM
questions on relocating ur gas cap and building a center console sonicdrft Other 9 03-14-2006 08:53 AM
I lost my GAS CAP!! Westside115 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 13 10-21-2001 04:25 AM
