Go Back   Automotive Forums Car Chat > Volkswagen > Golf
Old 12-02-2010, 08:57 PM
RH11 RH11 is offline
Crazy Electrical Problem-2005 VW Golf
Hi All,
I'm having a very annoying problem with my wife's 2005 VW Golf 2.0L auto.
Periodically, there will be a repeated sound of a switch activating, almost like the sound when the doors are repeatedly unlocked, the fuel door unlocked, or the hatch unlocked. I can't isolate where it is coming from or what it is. It may even be coming from the dash.
Also, while this is going on, the dash backlighting (not the dash lights but the backlight like when you turn your headlights on) will flash off and on as if you are turning your headlights on and off. Finally, if the radio is on this cuts in and out (I'm not sure if this happens all the time).
I've taken the car to the VW dealer and of course it doesn't exhibit the problem there. Has anyone experienced this problem? Any ideas what it might be? I was thinking it might be a relay or maybe the body control module, but I'm not even sure the Golf has a bcm!
Any help would be greatly appreciated.
Thanks,
Robert
Old 12-14-2010, 05:42 PM
betuaintgotthis betuaintgotthis is offline
Re: Crazy Electrical Problem-2005 VW Golf
Sounds to me like a poor earth point or possibly corrosion within a connector block. Couldnt tell you where these points are though sorry.
Old 12-20-2010, 10:31 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
sounds like the body module (called a comfort module in vw terms) is activating the alarm horn. Check out the battery neg cable to see if it is tight on the battery terminal.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Electrical Problems...... GaryCifers Corsica 6 01-13-2010 04:08 AM
crazy electrical problem fastgerman GTI 8 01-20-2006 06:03 AM
Crazy electrical problem jugriggs Eclipse Problem Diagnosis 7 01-10-2006 10:52 PM
Going crazy Electrical Problems JunkTitleGolf Golf 1 01-07-2006 10:48 AM
crazy electrical problems with 90 caprice oldskool90 Caprice 0 02-06-2004 10:34 AM
