Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-30-2005, 09:29 PM
jugriggs jugriggs is offline
Send a message via AIM to jugriggs
Crazy electrical problem
This is my first post...I was driving down the interstate one day...55mph 5th gear....car dies with no warning once I check it out i see the engine module fuse is blowing so I replace it...it blows whenever I turn the car over...however it will not blow if your not trying to start the car. There is no aftermarket wiring and I have checked everywhere for shorts whatever is shorting out is big. Also i am getting no spark naturally because the fuse is blowing...i know nothing about electronics i think it might be a bad ecm if anyone has any advice i would appreciate it
Old 10-30-2005, 09:33 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: Crazy electrical problem
You have a short to ground somewhere, replacing the fuse doesnt do anything, dont put a higher amp rated fuse in there either. I would suggest taking it to a mechanic unless you know how to use a volt meter and read wiring diagrams.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 10-31-2005, 09:26 AM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
A 1G ECM can be bought on eBay for $100 and a 2G for $200... I'd check all the wiring that I can, and if it's not outside of the ECM, it might be cheaper just to replace it. ...That's what most mechanics would do around here anyways. Other than that, you can't hurt anything with a volt meter (just don't lay the metal contact across 2 wires)... Right now might be a good time to learn to read a wiring diagram. PM me if you have any trouble with that.
'98 Eclipse RS
ENGINE: Twin Ceramic Ball Bearing T3/T4 with ceramic blades (20G for sale!), FMIC, 3'' Intercooler Piping and Down Pipe, Dump after Down Pipe, Walbro 255 FP, 450cc 4G63 Injectors, Greddy E-Manage, TurboXS DSBC (4/7psi for now).
SUSPENSION: Sustec Front and Rear Lower Tie Bars, Suspension Techniques Front and Rear Sway Bars, DC Sports Front and Rear Upper Strut Tower Bars, Eibach Pro Kit Springs, KYB AGX Adjustable Struts, Polyurethane Bushings Everywhere.
Old 10-31-2005, 05:15 PM
thanks alot for the post. I haved followed and tested everybit of wire that there is. So it must be the ecm. If anyone can shoot me a link where i can get one for around 200 i would apperciate it
Old 11-03-2005, 08:31 PM
papasoldier papasoldier is offline
did you check your major ground junctions?
Old 01-06-2006, 01:57 AM
your mom your mom is offline
Re: Re: Crazy electrical problem
I just got this same problem... its not the ecm so theres a wiring short some where. Does anyone know where I can get a wiring diagram for a 95 gsx?
Old 01-06-2006, 07:47 AM
nova1313's Avatar
nova1313 nova1313 is offline
Re: Re: Re: Crazy electrical problem
on ebay they sell the dsm shop manuals on cd. Those have wiring diagrams. They are simple to follow and cheap. I think mine was $10 shipped.
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 01-10-2006, 10:52 PM
WrecklessMM's Avatar
WrecklessMM WrecklessMM is offline
just had a problem just like that. it was the ecu on mine. found one at a junkyard. after buying a blown one of ebay.
