Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-01-2010, 05:50 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Popping/snapping noise from front end
Here we go again.
Weill my ZJ (98 Grand Cherokee 5.9Limited) started having an issue with some noise, sounds like the front axle, snapping/popping when in 4WD and turning. Last winter was fine, I had noo problems at all. Back in july I had to barrow a friends trailer and put it in 4WD to get out of his backyard, didn't want to tear it up and I noticed a loud popping/snapping noise when I was turning and pulling forward or reverse, pulled it out in his drive, put it back in 2WD, looked at the CV joints - didn't notice any torn boots or anything obvious so I thought heck with it I will check it out some other time, well I forgot about it until now, we got our first real snowfall here in western PA, nothing major but did remind me about my 4WD issue.
Anyone have any ideas?
I know I commented on another thread about this noise (someone else was having) but at that time the noise I was having (in my old ZJ) wasn't anything like this, it sounds like something is going to break....
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 01-08-2011, 01:13 AM
fmx_guy's Avatar
fmx_guy fmx_guy is offline
Re: Popping/snapping noise from front end
If yours is the same quadra track as mine its probably your transfer case popping (the chain is loose) does it pop when you pull a hill or when you accelerate hard? I eventually just took the front drive shaft out since it was auto-4x4. never fixed it just got rid of it. hope this helps in narrowing your search
Old 01-08-2011, 06:20 AM
No I don't have quadra-trac, I have select-trac.
But it end up being my right front AXLESHAFT, the boot came off and lost all the grease.
Old 01-08-2011, 06:30 AM
Rubbing/Grinding Noise from front end sashapup Grand AM 17 11-16-2005 03:07 PM
intermittent popping noise from front-end bertmaster2000 Camry/Camry Hybrid/Vista 4 12-13-2004 06:43 PM
98 GMC Jimmy: Noise from front end DZNZ Jimmy 12 10-23-2004 02:53 PM
98-v70,Noise from front end componets pml44 V70 2 06-11-2004 01:17 PM
vibrating noise from front end dtrober Jetta/Vento/Bora 0 11-03-2003 10:55 AM
