Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-01-2010, 10:32 AM
HOOKEDONSONICS HOOKEDONSONICS is offline
Left front wheel noise
Last week I had the front brakes and rotors replaced. The next day I noticed some noise but couldn`t pin-point what it was or where it was coming from. After a few days, I noticed it was coming from the left front wheel. When I back into my driveway and stop, it`s fine. When I move forward and stop I hear one clank / crunch. If I continue forward, it does not make the noise. It only makes the noise on the first forward stop after reverse. It does not do it in reverse. Sounds like the brake pad is shifting. I took it back to my mechanic yesterday and he was able to pin-point it to the left front wheel but can`t find where it is coming from. It is not coming from the brakes. Everything is tight except the upper ball joint has a slight movement. My mechanic says the slight movement of the ball joint is not enough to make that noise. I believe the noise is directly related to the brake job. I believe the 4x4 hub needs to come off to replace the rotor. Is it possible that something was not put back together correctly, like the hub? If it was the hub, wouldn`t I hear the noise more often? How about the axle joint? If that was the problem, I`m sure I`d hear the noise more often as well. The truck goes back Monday for further / more detailed testing. Any suggestions would be great.
Old 12-01-2010, 02:24 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Left front wheel noise
what year is your truck? It sounds like your wheel bearing is bad or the hub nut that hold the axle & hub in place is loose. It's not necessary to remove the axle nut when doing a brake job. The recommended torque for the axle nut is 175 ft/lb.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 12-01-2010, 03:14 PM
I Guess that would help to give my vehical information. It's a 1998 Dodge Ram 2500 4x4. The '94-'99 trucks have the brake rotor mounted behind the hub assembly whereas the '00-'02 trucks have slip-on rotors. The '94-'99 trucks, when doing a brake job on one of those trucks, requires the hub assembly to be removed to get the brake rotor off. The '00-'02 trucks do not. Now this hub was replaced 3 years ago and never a problem until this brake job.
Old 12-02-2010, 12:44 PM
Ok, I thought you had a 1500, but nonetheless, make sure your brake dust shield is not rubbing against the rotor. Also, if you have ABS, make sure that the dust shield is mounted on the actual hub bearing not the steering knuckle. This is to make sure the sensor pigtail doesn't get snagged and ripped.
Old 12-02-2010, 01:29 PM
Great!! I will be taking my truck to my machanic on Monday. He will be taking the whole assembly apart and I'll post results.
Thanks
James
Old 12-13-2010, 08:36 AM
Well, my truck is fixed. The problem was the rotor was shifting. The wheel studs are pressed in through the back of the rotor and into the wheel hub/bearing and the studs had a lot of wear on them. Anyway, my mechanic replace the hub, rotor. and studs.
Old 12-14-2010, 11:57 AM
urclueless urclueless is offline
Banned
the wheel would have to be loose/not properly torqued for that to have happened. that's some really poor mechanics. they obviously didn't properly press in the wheel studs when replacing the rotors
front clicking noise. wheel?? sohcd16 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 10-24-2010 08:53 PM
noise on left front wheel of 1991 s15 jimmy rickey446 Jimmy 0 12-15-2005 09:26 AM
Noise from my left front wheel 1999 Corolla wmcot Corolla/Matrix/Voltz 2 10-14-2004 04:48 AM
Left Front Wheel Noise MuthaTrucker Blazer 4 01-14-2004 08:52 AM
