It was 25 degrees this morning and my heat still does not work...I have bought brand new parts replaced the heater core, radiator, intake gasket,reservoir, and water pump. Realized this morning that when I turned the knob form cold to hot I did not hear it click over..A friend said something about my actuator could be unplugged? How do I know if it is unplugged or if I need to replace it...where is the plug?
Re: 1999 Alero Please help someone
Does the engine reach normal operating temp? Are the heater hoses hot? Does the blower motor work? The actuator is vacuum controlled, maybe a vacuum issue? You'll just have to look under the dash.
yes engine does reach normal temperatures it usually goes up to the middle mark sometimes even creeps up a little past the middle line...I have to bleed it alot for the temperature to stay under the middle line... Sometimes my belts also stop for a few seconds...I do not know about the heater hose will have someone check...Oh forgot to mention just bought brand new blower also...Air conditioner blows just fine...Just whenever I turn the knob to hot the air coming out still blows really cold...
Your belts stop? Can you ellaborate on this?
What motor does your car have? 3.4 or 2.4?
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
If you have to keep bleeding it to maintain temperature you are getting air in the cooling system, most likely exhaust gases. I had this exact same issue, although I would get intermittent heat and then it would go cold, get hot, and so on.
Turned out to be a very mildly blown head gasket. |
I'm sorry maybe it is my pulleys the belt looking things that you can see when looking down at your motor....Since the last time I emailed you I had to bleed it and the temp has not gone past the middle mark...is that where it is suppose to stay?Just need this car to last till beginning of next year then I can afford another one...lol...But what do you think about the heat...think maybe I should go ahead and buy a new actuator?oh and I have a 3.4 engine...Thanks for all the help
