Old 11-30-2010, 06:30 PM
schwanracing schwanracing is offline
2001 4.3l blazer engine problem
I replaced the lower intake gaskets on my blazer because of major coolant leak. While apart i found really bad oil sludge under lower intake manifold and cleaned as much as possible before reassembly. Got everything back together pressure tested coolant system found no leaks. changed oil and filter to be sure no contamination due to changing intake gaskets. I drove the truck about 150 miles with no problems. On my way home one night about 100 yards from my house the oil pressure dropped but not all the way it went down to about 1\4 way up on the gauge, as soon as this happened i heard a loud squealing noise that is constant with rpm. I checked oil level and it is good, took belt off to see what was causing squealing noise restarted engine and it was still there any ideas?
Old 11-30-2010, 08:17 PM
old_master's Avatar
Advisor/Moderator
Re: 2001 4.3l blazer engine problem
The intake gasket job probably loosened up some sludge and it worked its way to the oil pan. If that's the case, the oil pump pick up screen might be clogged causing oil starvation to the bearings. If the noise is still there with the belt off, it probably spun a bearing.
You have to know how it works,
to figure out why it doesn't.
The Following User Says Thank You to old_master For This Useful Post:
Booch (04-30-2012)
Old 11-30-2010, 09:26 PM
thanks for reply found bad main and rod bearings, guess i really screwed this one up
Old 12-01-2010, 03:32 PM
old_master's Avatar
Advisor/Moderator
Uh oh! That's too bad. Time for an engine. If you opt for a boneyard engine, it would be a good idea to remove a rocker arm cover and inspect for sludge before you go through the time and expense of installing it.
Old 12-01-2010, 07:23 PM
Jerry80871852 Jerry80871852 is offline
Do you know what kind of oil was used in this motor?
Have a great day,
Jerry
1992 Chevy S-10 Blazer
4 X 4, 4.3 W engine 3.42 gears
172,000 & still going
Sold
2010 Toyota Tacoma Double Cab 4X4 V6
4.0 V6 DOHC 24V VVT-i 236HP Engine
12,000 plus miles
Bought 10-22-11-2001 Toyota Camry LE SuperWhite 4 Door sedan I-4 89,680 miles
Old 12-02-2010, 03:09 AM
viggy58 viggy58 is offline
Jerry, I think I know where you are going with that question. I personally try to avoid oils that have paraffin additives in them. everyone has their opinion on oil brands though. I can tell ya that i've used castrol 5w30 for 100,000 miles, and when did my LIM gasket last fall, i had no deposits built up anywhere...
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 12-02-2010, 12:08 PM
That was my thought, I still remember seeing the inside of a few engines tore down years ago that only even had Havoline oil in them, & there be a few more oils that do the same thing theses days.
Plus I had been getting my oil changed at one of those quick lubes since I was disable in 2002, they get their oil in barrels, and I am not convinced its what it is suppose to be.
I am now back to changing my own oil after I had a stuck valve even though its a big effort for me. That happened about 100 miles after an oil change at the quick lube I changed my oil myself replacing one quart of oil with a quart of Rislone. Within 100 miles it had stopped sticking. I change it again at 3,000 miles, now the top side of my engine is about as quite as the bottom side.
Have a great day,
Jerry
Sold
12,000 plus miles
Old 01-04-2011, 06:10 PM
GTX high mileage 10w30 most of the time
Old 01-04-2011, 06:22 PM
old_master's Avatar
Advisor/Moderator
GM recommends 5W30 in these engines. A steady diet of 10W30 may have been a contributing factor for bearing failure. The bearings do not contact the journals, if they do, they fail prematurely. There is a "cushion" of oil between the bearing and the journal and 10W30 doesn't "fit" as easily as a 5W oil does. Thicker oil increases oil pressure, but decreases flow to the bearings. Just something to keep in mind
Old 01-04-2011, 07:04 PM
have any input on where i should find a reman engine
Old 01-04-2011, 07:10 PM
old_master's Avatar
Advisor/Moderator
Check with some local repair shops in your area and see who they recommend, or better yet, who they DON'T recommend. It would be best to stop by in person rather than calling them on the phone. There's probably a local rebuiler in Frankfort, if not, Louisville for sure.
Old 01-04-2011, 07:12 PM
thanks for info if i do decide to go with used engine do you know what year models i need to look at?
Old 01-04-2011, 07:19 PM
old_master's Avatar
Advisor/Moderator
Always best to stay with the same year, there's less fooling around making stuff fit/work and transfering of parts. Any 4.3L will fit, regardless of the year, but a good boneyard will be able to tell you what year(s) will work correctly with your wire harnesses and PCM/VCM.
93 s10 blazer 4.3l cpi engine problems maddog83 Problem Diagnosis 1 10-20-2009 08:42 AM
1994 S-10 Blazer 4.3L Transmission shifting problem crazed2881 Problem Diagnosis 14 02-26-2009 06:50 PM
1994 caprice 4.3L V8 engine problem zicode Caprice 8 02-09-2006 09:28 PM
1995 S10 Blazer 4.3L 4x4 idle problem riverjamie Blazer 0 02-08-2006 08:35 PM
intermittent A/C problem 2001 4.3L 4x4 BlazerNYC Blazer 13 06-30-2005 06:00 PM
