Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-01-2004, 09:29 PM
zicode zicode is offline
Question 1994 caprice 4.3L V8 engine problem
I have a 94 caprice classic with a 4.3L V8 and here is my problem.
The car will start and run ok when it is cold, but as it warms up the timing advances up and up. Then the car has no power(it will not even move) and it back fires the lifters rattle etc.......
It all started out when the drivers side catalitic converter went bad.
The part list goes as follows;
EGR valve- new
exhaust all from the manaflod back- all new
PCM- new and reprogramed
ignition control module- new
ignition coil- new
o2 senser- 1new 1 old
But the car still thows an error code of 42, and the timing still advances even when the car is at an itle.
CAN ANY ONE HELP ME?????????????????
Old 06-01-2004, 11:22 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
Re: 1994 caprice 4.3L V8 engine problem
check your idle air screw on the throttle body,
it coud even be your throttle body positioning
sensor. i had a 91 camaro that done that
same thing mine was the throttle body
positioning sensor.
Old 06-03-2004, 07:10 PM
Thank you but that has been check and does not have to do with the timming advancement.
Old 06-03-2004, 07:14 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
4.3 v8??? the 4.3 is a v6
Old 06-03-2004, 09:06 PM
CD Smalley CD Smalley is offline
They both exist. But the 94-96 Caprices did come with a 4.3 V8, 265CID I think. Basically the same engine as a LT1, just a smaller displacement.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 06-05-2004, 06:42 PM
HLandin's Avatar
HLandin HLandin is offline
While it is a V8 at 4.3L, it was not an LT1. Check out http://www.9c1.com/brochures/index.html
for statistics almost every single year of the Caprice 9C1.
Old 02-09-2006, 07:08 PM
ridnbblchvycuz's Avatar
ridnbblchvycuz ridnbblchvycuz is offline
Thumbs up Re: 1994 caprice 4.3L V8 engine problem
I have the same problem. I spoke with some people and if I don't do the work it's gonna run me around $800 dollars. <<-----Me while on the phone with the Cadilliac Dealership, after speaking with my mechanic.
After I looked for the prices of the parts myself in my Chevrolet Classic Industries Parts & Accessories Catalog for the parts have accepted the dealer amount seeing as though the motor is running great now and plan to rebuild the tranny in the spring.
o yea I have a 1994 Chevrolet Caprice 4.3L V8 and a couple of people have told me that the motor was built similar to a corvette motor.
Old 02-09-2006, 08:58 PM
kahjdh's Avatar
kahjdh kahjdh is offline
The 4.3 is the "baby LT1". I think it was just destroked
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 02-09-2006, 09:28 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Yes, it was referred to as the "baby LT1" - it was more than destroked, it was also debored over the 350. It has the 305 (3.74") engine bore with the 302/283/265 (3") stroke. It had the same engine management system and induction/ignition systems of the LT1 as well. RPO number was L99.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
