Go Back   Automotive Forums Car Chat > Buick > Century
Old 11-29-2010, 09:28 AM
cork1958's Avatar
cork1958 cork1958 is offline
[Solved]1988 Buick Century Ltd. w/H.D. Cooling
Hello all,
Just joined and already have a question (isn't that the way it goes)
What type radiator is in a 1988 Buick Century? Looking at the online parts stores in my area they have one listed as "w/H.D. Cooling." What is H.D. cooling and does my car have that. From the searches I've done, I'm guessing it's an oil cooler?
Here's a link to the radiators listed for my car. Which one would I want?
http://shop.advanceautoparts.com/web...ge-_-Radiators
Thank you
Edit:
Marked as solved although it wasn't really an issue
Old 11-29-2010, 09:37 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 1988 Buick Century Ltd. w/H.D. Cooling
Welcome to AF!!
If you have AC make sure to get the one that will work. Heavy duty cooling indicates a larger radiator usually if you have a HD radiator you will have a thicker core than a standard radiator. Installing a HD radiator in your car won't hurt anything and it will help your car run cooler although it will require more coolant than a standard radiator.
Old 11-29-2010, 07:35 PM
cork1958's Avatar
Thanks GTP Dad!
That was almost to easy as far as HD means heavy duty, which was my first thought, although searches for this had me thinking otherwise almost.
Yes,
I have air conditioning.
I'm not and don't even want to be to mechanically inclined, as far as working on cars. It's just not my thing what so ever. How do I know if I have oil cooling lines or tranny cooler lines?
Thanks again
Old 11-30-2010, 08:05 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Welcome to AF cork1958.
It would help to include what engine your car has, as this has a big impact on what radiator you need.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-01-2010, 12:26 PM
cork1958's Avatar
Hmm?
Guess that would help, huh? Just clicked the link I provided above and it doesn't take you to the make/model/year of my car, unless you're signed into that site.
Anyway, it's the 2.8L motor w/AC..
As it is, had my mechanic talking to the guy at Advanced Auto yesterday. He's ordering BOTH the radiators that are supposed to fit my car with H.D and max cooling as without having the radiator out, we can't measure accurately to tell how tall or wide, the core is. Going to remove radiator and take it with us for comparison Friday.
Thanks
Edit:
New radiator is all installed and functioning perfectly. All nuts, bolts, clips, etc., came out/off as easy as pie! If you can believe that?!!
Something is inside the oil pan of a 1988 Buick Century, 4cyl, 2.5L hansen89 Century 1 08-08-2009 07:32 AM
1988 buick century <starters> weeziek83 Century 1 09-03-2008 02:38 PM
1988 Buick Century 3.8 Hilsep Century 1 03-31-2008 07:06 AM
89 Buick Century cooling fan relay drpaul87 Century 2 06-21-2007 02:25 PM
1988 Buick Century Timing change=more problems mom_of_davian Century 6 10-02-2006 01:11 PM
