So, the timing in our car went out so we took it all apart and got it back together. Anyway, it wont start.! We checked and made sure it was lined up and the #1 piston was up also! We even took it apart again to rotate the bottom gear. To make a long story short, its been apart about 6 times. Whats next?
Re: 1988 Buick Century Timing change=more problems
What engine?
what kind of engine is it.
95 Plymouth Neon 2Door 2.0L SOHC 89 Buick Century Custom 3.3L ____________________________ What to see pics of my cars. Go to www.cardomain.com and look for musclecarfan6. Rate or leave comments if you want. |
Sorry, about that! its a 3.8L V6 and The thing is, after we took it apart and messed with it again we got it to start, now it wont stay running and theres a pretty good leak ONLY when its running! Oil! And if you know anything about trannys...is it going bad or what does it mean when it had troubles only shifting to 2nd?
What type tranny do you have? automatic or manual.
Automatic
I had a similar shift problem, replaced the vacuum modulator. Fixed my problem. There is a vacuum line that runs from the modulator to the throttle body, when the diaphragm in the modulator ruptured, the vacuum sucked tranny fluid into the throttle body, and because the air filter housing was lower than the throttle body, the bottom of the air filter housing filled up with transaxle fluid. On my vehicle, the modulator is on the outside front of the transaxle, not hard to replace. I can't guarantee that replacing the modulator will fix your shift problem. |
