Old 11-29-2010, 09:25 AM
sdcrain sdcrain is offline
Question cataletic converter
2000 chevy Blazer s10 anyone know what the symtoms are for a bad cat. converter
Old 11-29-2010, 02:40 PM
laxman21's Avatar
laxman21 laxman21 is offline
Re: cataletic converter
Any codes?
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 11-29-2010, 02:49 PM
danielsatur danielsatur is offline
P0420 (bank1) / P0430 (bank 2) - Catalytic coverter is broken, or blown!
A plugged catalytic converter (No codes) can choke an engine out, run hot, and cause random misfires.
Old 11-29-2010, 06:56 PM
viggy58 viggy58 is offline
get it up to temp, then drive to a muffler shop like meinike. ask em to check the pre and post cat temps. they have the laser thermometers. takes about 10 seconds.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 11-29-2010, 07:37 PM
A scanner can pull the catalytic converter temps!
Whats normal?
Compare bank1 with bank2.
Old 11-29-2010, 10:14 PM
2000 chevy blazer thanks for the help, what is happening is it surges under 2000 RPM runs smooth @2000RPM and over but then it will just die some times it will start after about an hour some times it wont start at all
Old 11-29-2010, 10:21 PM
TCGrove TCGrove is offline
Keep in mind when looking at the catalytic converter your O2 sensors come into play. When the converter doesn't do it's job the O2 sensors start reading incorrectly and your fuel to air ratio starts getting thrown off. If you gut the converter you will definitely get a code because the pre and post readings are too close. You can buy little extensions that keep the post sensor out of the gas flow (runs cooler) to correct for this. I had problems with poor acceleration and idling until I change the O2 sensors and converter. The converter was totally plugged up after 150,000 mi. on my 99 Blazer.
Old 11-30-2010, 09:54 AM
thanks will check this weekend
Old 11-30-2010, 11:17 PM
Replace Air filter, and clean MAF sensor.
I would only replace the upstream H02 sensors.
Old 12-01-2010, 11:29 PM
jakeyf08 jakeyf08 is offline
I have a few questions regarding this topic. I got a bad misfire on the way home from work today and the service engine light was flashing. I crawled under my blazer when i got in the garage and the cat was glowing orange. is the cat plugged? Prior to this I had a bank 1 running lean code (p0420).
Old 12-02-2010, 04:05 AM
jakey, i'd say that sounds plugged. def something is wrong. but start a new thread!!!!
2001 Chevy Blazer
4.3L 5 speed manual
145k miles
146k miles
1991 lebaron convertible top start & stop tomas-convertible Lebaron 4 08-20-2012 03:44 AM
Convertible Canvas Help Kin2InuYasha Non-Performance 2 01-19-2011 05:06 PM
96 Sunfire Convertible Tack Strips 96DropTopFire General Discussions 0 03-03-2009 05:21 PM
Anything to look for before buying 2002 GT convertible? jimhockey74 Mustang Talk 0 02-12-2009 03:19 PM
Cataletic Converter, 3000 RPM OU LOU LS | MKZ 3 03-23-2007 02:15 PM
