Go Back   Automotive Forums Car Chat > Mercedes-Benz > S-Class
Old 11-27-2010, 05:27 PM
Wil C Wil C is offline
1992 500SEL over heating issue.
Hey, i have a 500SEL over heating. I believe the culprit is the fan driven by the engine.
I can literally stop the fan with a stick, possible my hand if i wanted to when its over heating. That's a sign that the fan clutch is gone correct? Does anyone know how this system on the 500sel works? Any experienced replacing it?
Any help much appreciated, Thanks.
Old 11-27-2010, 07:23 PM
danielsatur danielsatur is offline
Re: 1992 500SEL over heating issue.
A thermomatic fan clutch will engage at a certain temp, a mechanical fan clutch works all the time. The symptoms of a bad fan clutch will cause over heating at highway driving 55MPH+
What happens when you turn the heater on max, during the over heat condition?
Do you got Heat?
No Heat?
Will the temp guage go down?
Old 12-01-2010, 03:26 PM
eclass eclass is offline
rev engine to 1500 rpms when hot, if fan does not lock in replace it.
Old 08-29-2011, 09:39 AM
sammydose sammydose is offline
It could be a lot of things. Faulty thermostat, faulty water pump, radiator hoses collapse, viscous clutch defective debris in the radiator ducts clogged radiator, faulty temperature sender motor can not be over-heating, etc. My problem was the viscous clutch.
[Spam link removed by moderator.]
2000 LS NO POWER TO AC/HEAT controller Cassious Regal 1 12-17-2009 06:29 PM
97 Mystique Over Heats and Causes Tranny Issues shivparekh Mystique 6 01-11-2009 02:51 AM
Pls help 88 dodge caravan over heating no heat belvnmajk Caravan | Voyager 2 11-17-2004 12:28 AM
over heating issue badassjorge Monte Carlo 2 07-05-2004 01:36 PM
1992 Achieve SC- Heating issues GBC Chairman General Discussion 1 12-17-2003 09:54 AM
