Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 11-27-2010, 03:49 PM
grizzly102 grizzly102 is offline
1998 mercury
starts and stalls in a few seconds battery went bad had to replace trouble since ran fine before
Old 11-27-2010, 04:22 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 1998 mercury
Make sure there are proper connections on the battery. Loose connections can cause all sorts of problems.
Also try starting the engine with the throttle pressed just a little bit (just barely off idle). If it stays running with the throttle depressed and dies when you let back off to idle, then it is likely the Idle Air Control (IAC) Valve.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 11-28-2010, 11:05 AM
Re: 1998 mercury
dosent matter where the throttle is dies withen 2 seconds ran great till i replaced the battery
1998 mercury grand grizzly102 Cars in General 0 11-27-2010 03:29 PM
Rabbits chewed up F8CE-AE car part for 1998 Mercury Tracer (Ford Escort) adam2003w Escort 4 12-04-2005 08:00 PM
1998 Mercury Grand Marquis Spark Plug Removal silverdollar22 Grand Marquis 3 08-07-2005 09:28 PM
1998 Mercury Sable Brake Lamp Replacement rousseaur Sable 5 01-26-2005 03:32 PM
1998 mercury sable mercury Engineering/ Technical 2 11-28-2001 09:05 AM
