Old 11-27-2010, 10:57 AM
woodcharliem woodcharliem is offline
2000 grand am 3.4
ok did a head job on the car about a year ago and have had a problem with the car since it runs fine when u r on the road driving but when u first crank it up you have to hold the gas to keep it running and even after the motor warms up it still has a skip to it when u stop the interior lights also dim when u let off the gas and the serpinten belt squeals when u first cranck it up
Old 11-27-2010, 04:37 PM
diem diem is offline
Re: 2000 grand am 3.4
Have you tried new a new belt and new platinum plugs? What kind of plugs are in there now?
Old 11-27-2010, 09:26 PM
i dont remember the type of plugs i put in it after the top half was redone but the belt does seem to be a little lose i had an issue with the tensioner pulley but i replaced it but like i said the belt still seems to be a little on the lose side and it was a new belt when i put it on
Old 11-27-2010, 09:28 PM
It shouldn't deflect much at all, let alone feel loose. To be honest, the best belt I've found are the cheap valucraft belts from Autozone. I'd never purchase any other valucraft product, but these belts work great on the 3400.
You might try pulling the plugs and inspecting them. Anything other than Platinum is known to foul on these motor. They can't handle the waste spark.
Old 11-28-2010, 12:26 AM
thephantom1492 thephantom1492 is offline
It's not the belt!
your car could almost run fine without a belt! however if I'm not mistaken the water pump is on the alternator belt too, so would overheat quickly. Another issues would be with the air conditionner as the compressor is there. And of course your battery would run dead soon...
So, beside those "small" things, it can'T do anything else.
When you redid the head, could you have messed up the timing? Are you sure you reconnected every sensor correctly? What about every vaccum lines? Could dust have entered the MAF sensor?
Old 11-28-2010, 07:40 AM
He said the belt is squeaking at start up. It could be slipping. If the belt feels loose it's definitely a problem. The car can run without a belt until the battery dies and car overheats. The WP and Alt need the belt to operate properly.
Old 11-28-2010, 04:36 PM
I was refering to the stalling issue.
Yes there is a problem with the belt, but that is not what cause the stalling.
3.4 From 2003 Monte Carlo into 94 Firebird? iamdallas Engine and Transmission 0 03-21-2010 08:39 PM
alero 2000 overheating v6 3.4 no leak in the head gasket ihatethealero Alero 2 01-19-2010 09:42 AM
2000 Grand Am 4-Cyl shuts off when A/C turned off INGUES Grand AM 19 08-19-2008 06:16 PM
2000 grand cherokee 4.0 won' shift freebird432003 Grand Cherokee | Grand Cherokee SRT8 1 06-19-2006 08:19 AM
2000 Grand Cherokee 4.0 Hesitation, stutter thedeer2 Grand Cherokee | Grand Cherokee SRT8 3 01-21-2006 10:11 PM
