Old 11-24-2010, 04:41 AM
papasmithnc papasmithnc is offline
Banned
Alternator Removal Question
94SL with 108k.
I have a pronounced squeaking sound coming from the alternator. I know it is this because I squirted just a bit of wd 40 behind the pulley and it stopped momentarily. Of course the bearings are going bad.
I need to know, how difficult is it to replace the alternator in these cars. Does it involve going through the same procedure as changing the belts and whatnot?? If not, is there an outline of the procedure somewhere on the net that someone knows about?
Thanks,
Dave in NC
Old 11-24-2010, 02:03 PM
inafogg inafogg is offline
Re: Alternator Removal Question
are you sure its not the belt squeaking.remove the belt & spin alt to see
if you hear or feel anything from the alt bearing
as far as replacing the alt should be straight forward remove belt,wires ect.
but dont no the set up, auto zone should have procedures
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 11-25-2010, 11:30 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
The alt bearings are inside the alt so if its anything on the alt, its the pulley. I would bet its the belt squeaking.
If it is the alt then it depends on if its a DOHC or SOHC on how hard or easy removal is.
Old 11-28-2010, 10:14 PM
Banned
Thanks guys regarding the heads up on the belt squeaking. Doesn't sound like it though. I'll certainly check before buying a new alternator.
Old 11-29-2010, 09:27 AM
check all pulleys/tensioner while the belt is off
Live For Today
Yesterday is gone,
Old 12-24-2010, 11:00 PM
bob55663 bob55663 is offline
for me in my 93 3kgt sl i had to remove the tensioner and then the radiator to have enough clearance for the alternator to be removed from the top
Old 12-28-2010, 12:46 AM
Banned
That's interesting Bob. Hopefully, there is a difference in the 1st and 2nd generation in this regard and I don't have to do that. As it stands now, I am going to wait for warmer weather before I do anything.
Old 12-28-2010, 07:21 PM
Stealthee's Avatar
Removal of the rad is not necessary, but removal of the drivers side fan makes things easier.
All purpose cleaner to remove oil, grease, tar... mikecooper General Tools 3 02-15-2011 09:15 PM
84 Accord alternator removal question kd4rmm Accord/TSX/Accord Hybrid 4 07-07-2004 03:28 PM
91 Si Alternator Removal Aiwen '88 - '91 Civic | CRX | Wagon | Shuttlee 9 05-12-2003 08:50 PM
Alternator removal Cervantes Cherokee 0 04-22-2003 08:20 AM
