Old 11-23-2010, 12:16 AM
habitat814 habitat814 is offline
2000 Intrigue burning smell from engine
I just changed my coolant reservoir on my 2000 Intrigue because it was leaking and my car kept on over heating. Now, I keep smelling a burning plastic smell and it looks like one of the pulleys is overheating and glowing! I attached a link to the video that I shot just a few minutes ago. I don't know if its the crank pulley or what but either way, why is it glowing? Thanks for any insight or help!
-Dustin
http://www.youtube.com/watch?v=LoffCukQodM
Old 11-23-2010, 01:26 AM
shaallkie shaallkie is offline
Re: 2000 Intrigue burning smell from engine
is that behind the water pump pulley? if so then something got stuck in it or the blades got bent and needs to be replaced
Old 11-23-2010, 01:57 AM
I think its below the water pump pulley.
Old 11-23-2010, 10:09 AM
carbon02 carbon02 is offline
That's the air conditioning pulley/clutch assembly. My guess is the AC clutch/bearing is bad causing a lot of heat.
To my knowledge there is not a standard pully avalible that allows you to bypass the AC system on the 3.5L there is for the 3.8L . Some have tried removing the belt and spraying lubricant behind the AC pulley, but if your creating that much heat, it's shot.
Some of us have followed the repairs of KrivasAuto a member on this site. Check out his page at http://99intrigue.shutterfly.com/activityfeed and look at AC compressor. There's more info and pictures there than you'd ever want.
Ultimately I can't see a cheap fix for this, as you need that pulley for the belt to go around. Maybe a shorter belt with a custom routing may work, but there was never an option for no AC on this 3.5L Intrigue.
Good Luck-
2002 Oldsmobile Intrigue, 3.5L, GX --121,000 Miles as of 2/4/2011
2000 Oldsmobile Intrigue, 3.5L, GX --81,000 Miles sitting in garage awaiting shift kit P1811, and potential water crossover gasket repair.
Old 11-23-2010, 11:59 PM
Ok the belt snapped on me today. It was the ac compressor that had a bad bearing on it causing it to seize up and snap the belt. I ended up buying a belt that was 10 inches shorter than the normal serpentine belt and by passed the AC pulley. It was a tight fit but it ended up working. I thought it was a timing belt and thought I was up poop creek without a paddle.
Old 11-24-2010, 09:29 AM
Please keep us posted on the success of running this shorter belt, and post the part number of the belt that you used.
This may be a nice alternative to those of us in nothern climates that can get by without the AC compressor
98 camry--burning smell from hood rubs Camry/Camry Hybrid/Vista 10 11-20-2004 02:06 PM
Burning smell from engine compartment canyonD Venture 1 11-16-2004 10:07 PM
Burning smell from rear fender well Anew522 4Runner/GX470 5 01-26-2004 09:39 PM
Burning smell from under hood. sjs92 Taurus | Taurus Wagon 3 12-15-2003 12:25 PM
burning smell from clutch Eric Lee Diablo 21 11-12-2003 11:45 PM
