Old 11-23-2010, 12:02 AM
sdcrain sdcrain is offline
transfer case vacuum switch
2000 Chevy s10 blazer, does anyone know where the vacuumswitch for the transfer case is I look , cant find it
Old 11-23-2010, 07:20 AM
Blue Bowtie's Avatar
Registered Offender
Re: transfer case vacuum switch
Look beneath the battery tray for the actuator, and along the top edge of the cowl for the vacuum switch. The switch was moved off the transfer case sometime in the late '90s.
Old 11-23-2010, 08:20 AM
found the one under the battry followed it to the firewall but there is another line from there that goes over to the drivers side fender and has a tee in it one line goes to the front of the car and the other disintergrated, the part that was left turned like it went towards the trans, I went to autoparts store and asked to see one for a 2000 and he brought me out something with a hose connection on one end and a bullet on the other, but did not know where it went
Old 11-24-2010, 08:34 AM
laxman21's Avatar
laxman21 laxman21 is offline
What TC do you have? THe 236 4 button will have it on the fire wall. The 3 switch is still on top of the transfer case. Follow the vacuum line at the TC and it will lead you right to it.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
2000 blazer No Transfer Case Vacuum Switch? paulp64131 Problem Diagnosis 10 01-31-2015 10:16 PM
Tranny Fluid in transfer case vacuum switch lines ???? scholzee Problem Diagnosis 6 01-02-2008 03:34 PM
Transfer case vacuum switch chcknugget Problem Diagnosis 1 12-04-2007 09:57 PM
95 blazer transfer case vacuum line phuz Blazer 0 12-14-2004 11:33 AM
1997 Blazer LT AWD transfer case 4x4 switch vanguard7 Blazer 4 03-24-2004 05:56 PM
Tags
transfercase
