Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 11-22-2010, 02:39 PM
taet1971 taet1971 is offline
Brake Line Leak
How do you replace the rear brake line on a 96 chevy impala ss? I bled the brakes and have a leak in the rear.
Old 11-22-2010, 06:50 PM
maxwedge maxwedge is offline
A990 racer
Re: Brake Line Leak
You can buy made up lines of different lengths, measure the routing and length and replace it, do not let the m/c run dry doing this as you may have the get it on a special scanner the bleed the abs unit.
Old 11-26-2010, 10:16 AM
j cAT j cAT is offline
Re: Brake Line Leak
since I own this vehicle , yes I too had this blow at the driver side rear axle area. I replaced a section of this line that was bad rather than the complete line . this is because the bad area was only around the left rear wheel...
to do this the old existing line must be good where you cut in the new section. also you must use a double flare tool with the proper fittings..
Brake Line Leak? Getting Screwed by Dealer? HpyGlmore2 Camry/Camry Hybrid/Vista 17 03-22-2007 04:16 PM
Brake Line Leak LimitedTahoe00 Tahoe 2 01-22-2007 02:07 AM
Oil Pan Leak repair and brake lines muddler Crown Victoria 3 07-08-2005 04:13 PM
92 maxima brake line leak jamey666 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 09-23-2004 07:38 PM
