| WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
Ferrari 458 Italia (Fujimi)
Hi all
I have a week off so I've decided to start something new and try to finish it before I have to go back to work. The kit is the 458 Italia from Fujimi, well discussed kit with many pros and just as many annoying cons. Built examples tell me that it still builds into a fantastic-looking model but that also might have a lot to do with the modellers. We'll see. I'll try to keep it as close to box stock as possible and I'll also do the modifications that have the right effort/return ratio. Parts that will be painted body colour ![]() I decided to remove the lower rear mesh - so that I do not lose the mesh detail there. ![]() ![]() Same for the mesh in the front fenders Before ![]() After ![]() Both of them were quite easy to do - just grind away with the dremel from the inside and then clean up. The front one is done in order to make painting easier - I see no way in hell I'd been able to paint that mesh black after the body was painted. I was also really tempted to cut out the little triangular mesh areas near the headlights but it's possible to paint it afterwards and I don't have PE saws anyway, so they stay in. At the moment I'm at the cleanup-primer stage. Here are some of the parts drying in the dehydrator ![]() I do need some help, though. What is your take on the colour of the dark parts on the body? The front grille/winglets, the areas at the back around the mesh I cut out, the lower parts of door sills - in some pictures they look black to me but in others the are that sort of weird metallic gray colour. Any ideas? Also if it's not semi-gloss black, what would you use to replicate that? Cheers, Alex
![]() Would love to resume my duties as AF's own official thread bastardizer!!! ![]() 1:29:53.435 || 207.316 || 310.596 |
Re: Ferrari 458 Italia (Fujimi)
I'm dying to get the Revell kit in my hands...the Fujimi kit left me wanting...it's okay, looks good on the shelf, but was rather disappointing to build. It's like they put their "D" team on the project instead of their "A" team.
My Fotki Album |
Thanks, Bob. I guess I'll go with black for this one.
I want the Revell kit as well but, at the risk of going off topic, it's also only good enough, just. I guess Revell's B-team is on par with Fujomi's D-team ![]() Can I ask you to elaborate on the sink marks on the Fujimi body? Don't want to miss any hard-to-find ones... Mozilla/5.0 (Linux; U; Android 2.2; en-ee; HTC_DesireHD_A9191 Build/FRF91) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1 |
![]() Also it pays to ditch at least the front brakes. The caliper is much smaller than the rear brakes ![]() I just built the Fujimi Prius for magazine review. Aside from the simplistic interior tub (that is similar in design to the 458), overall it clearly is a better engineered kit. Fujimi used their A-/B+ team on that one
My Fotki Album |
i) what would you recommend as replacement brakes? ii) don't suppose you've seen the cr-z kit? I saw the concept at the 2008 motorshow here and developed a bit of metal love then and there...
AF's Guidelines Read them. __________________ ![]() Currently in the process of re-hosting my photos. If any go missing, drop me a PM. |
Haven't gotten the CRZ yet, hopefully around the holidays. Currently I have an Abarth 695 Ferrari Tributo to build...it's okay, they got the seats right but the wheels are too small, steering wheel isn't correct, bad tires and I'm sure I'll have to go medieval on the wheels/brakes like my standard Fiat 500 to get the wheels/tires centered and inside the fender openings.
My Fotki Album |
Looks like good progress so far, i'll definately keep an eye on this one
https://www.instagram.com/ecemodelling/ |
sorry for continuing the hi-jack...
so it's only the caliper that needs replacing?
No problem at all, this discussion is very helpful.
Now ... the calipers. I think I know what the problem is, Bob - the Fujimi D-team. Let's start wit the picture of the kit calipers ![]() I've sanded off the raised (thankfully! Don't have to fill it like on the Scuderia kit) Ferrari script. Now look at what the calipers look like on the real car. Comparing the two it's obvious that parts 6 and 7 are for the front and 8 and 9 are for the rear. 6 and 7 are also a little bigger, like they should be. Now let's look at the Fujimi instructions. D6 and D7 are indicated for the rear while D8 and D9 - for the front. To me it's quite clear that there is a mistake in the instructions. I haven't checked how the correct parts will fit on the parts of the caliper molded together with the hub but I know that I'll be using the correct version. Perhaps this is something for those considering building this kit to keep in mind. And just to show that I'm making some progress - some painted parts in the dehydrator. I like black interiors and I'm not going to apologise for that
Some more pictures of the brakes. unfortunately Fujimi didn't just make a mistake in the instructions - the back parts of the calipers molded together with the hub are also switched back to front.
Rear hub with the correct rear caliper face ![]() Same with the brake disc ![]() Fronts ![]() ![]() What I'll do is I'll trim the back part of the caliper somewhat for the rears and I'll just leave the fronts as is. That's not the most accurate solution but it's the easiest. The caliper halves (holes) align just fine and there are no issues with the brake discs installed. Again, those building this kit, keep an eye out for this peculiarity. Best, Alex
Nice..your notes is definitely useful for reference
![]() btw, did you swap the disk rotors as well? since the rear suppose to be smaller to the front disk |
![]() Two of the rotors are indeed slightly smaller than the other two but since the parts are off trees I don't know anymore which ones were which numbers I cannot tell if Fujimi swapped them too during their design process. Larger rotors do have the details that are accurate(ish) to the front rotors on the real car and the plan has always been to use them at the front and that's how I used them for the mock-up above. I didn't bother with the Fujimi instructions back then because it seemed clear-cut. Same reason I was quite confused about Bob's comments about the caliper sizes because the ones on trees that looked like they belong at the front actually were slightly bigger than the ones that looked like rear calipers ![]() Edit: I take that back, the engravings on all of the rotors aren't really accurate so I'll just go with the larger ones at the front and smaller ones at the rear
lol...i see, actually it doesn't really matter now, since everything is mixed up
i agree with you the bigger one should be on the front
a really cool start... im planning to start this kit too... your WIP will be my big help and guide.
Completed Lexus LFA http://www.automotiveforums.com/vbul....php?t=1122869 Completed Ferrari 458 Italia http://www.automotiveforums.com/vbul...php?t=1079425# Completed Nissan GTR http://www.automotiveforums.com/vbul....php?t=1054794 Completed WALD GTR http://www.automotiveforums.com/vbul...44#post7018544 |
Forget the Fujimi instruction sheet, better to build this kit with only good detailed pictures. Max
