Old 11-21-2010, 10:33 PM
localfirefighter localfirefighter is offline
1997 Taurus CCRM F6SF-12B577-AA wiring diagram
My CCRM (#F6SF-12B577-AA) started smoking a few days ago, so I stopped driving the car.
It still starts & seems to run fine, however; When I took off the cover to the CCRM I noticed the the apx. 1" X 1" relay plugged into the in the K4 spot on the board is fried (along w/ it's section of the board). What I'm wondering is:
1.) Which component does that relay go to?
2.) Is there a website I can download the wiring schematic for the entire CCRM from?
3.) Should I replace the component 1st before the whole CCRM?
Thanks in advance for your reply!
Old 11-22-2010, 08:17 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 1997 Taurus CCRM F6SF-12B577-AA wiring diagram
Can you tell which connector pins the relay contacts go to? If so I can probably tell you what component it does to. I have a block diagram somewhere of the CCRM, but not a detailed wiring diagram or PCB color keys.
I'm not sure it will serve you well to replace the relay and repair the traces versus purchasing a used CCRM from a salvage yard, but it would be good to check the circuit that was powered by the relay for damage. Have you dissected the relay to determine if the contacts inside burned up or if the coil melted? Any signs of moisture on other traces inside?
-Rod
Old 11-22-2010, 03:52 PM
Thanks for the Reply Rod!
No, I can't tell which connector pins go to the fried relay with absolute confidence, but it looks like they might be 1/13 & 2/14 as they're closest to the fried relay. None of the wires coming from the block have any sign of burn-back & there's no sign of a moisture issue.
I totally agree that it's not worth it to repair the burned relay & board! I was planning on replacing the entire CCRM & have found many used ones on ebay, but I'd rather not waste the coin if whichever component the burned relay goes to caused the issue. Which is of course the reason I made my original post.
Lastly, no I haven't taken the relay apart & am not to sure I want to. I put the CCRM back into the car today & have been driving it around town without any issues (other than the burning smell). I went by NAPA & didn't get any help there, but he did bring up a good question: Why haven't any of my indicators on my dash lit up? Hmmm? I did try out my a/c & found it not working, so that might be it. Fortunately for us, it's snowing now so we won't be needing a/c anytime soon.
-Sean
The Following User Says Thank You to localfirefighter For This Useful Post:
taurusRus (08-25-2012)
Old 11-22-2010, 06:55 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Here ya go if it is a 3.0 2 valve.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
The Following User Says Thank You to way2old For This Useful Post:
Old 11-22-2010, 08:37 PM
shorod's Avatar
SHO No Mo
Keep in mind that the A/C is engaged to make the defroster more effective, assuming the ambient temperature is above freezing.
-Rod
1997 Clio Airbag + wiring diagram casahit Clio/Clio II/Clio III 1 12-03-2010 05:54 AM
1997 Taurus wagon -alternator? Greeneyes_2006 Taurus | Taurus Wagon 6 04-12-2010 02:41 PM
1989 S-10 Blazer Wiring Diagram 89S10Blazer S-10 1 01-07-2010 11:01 AM
65 GMC tail light wiring diagram dcarreno2006 General Discussion 0 08-11-2009 12:13 AM
1992 ford taurus ccrm diagram edu-uio Taurus | Taurus Wagon 1 04-09-2007 02:49 PM
