Go Back   Automotive Forums Car Chat > Toyota > ES300/ES330/Windom
Old 11-20-2010, 09:51 PM
jalopyjoe jalopyjoe is offline
95 Lexus cracked radiator problem
My friend is having a problem with the radiators lasting more than a year. This is his 2nd one that he replaced. When the factory one cracked and got replaced 2 years ago, that radiator cracked a year later. Then few months ago, the radiator cracked again.
Now I know radiators don't last forever, but 1year seems strange. And it's always a plastic radiator that is sold for it. Are there any metal ones available out there? Are there anyone out there with the same problem that resolved this issue? Any suggestions?
Thanks
98' S-10 4x4- Nice Truck
92' Previa
Now a 99' Camry
Old 11-21-2010, 08:44 AM
ctwright ctwright is offline
Re: 95 Lexus cracked radiator problem
That many radiators it sounds like the radiators aren't your problem, too much pressure is building up in them, you need to make sure you are using the proper radiator cap for the radiator you are using, with the proper pressure rating, that way when pressure builds up too high it will relieve pressure. Have you been using the same cap or have you tried different ones? Have you checked your thermostat? It may need replacing as well. Maybe someone else will come back and reply what pressure rating cap you would need for your particular vehicle.
Old 11-22-2010, 12:26 AM
I think it's the factory cap. Maybe that might need replacing, I'll check. I'm not sure if the thermostat was ever changed. I'll find out. But he got it used, so I don't think he would know if the stat was changed.
92' Previa
Now a 99' Camry
1990 Ford Econoline Van Radiator Problem, I think.. ariel418 Econoline 6 05-12-2009 06:40 PM
cracked radiator TexasGypsy Rodeo | Passport | MU 7 07-17-2006 06:27 PM
Cracked Radiator, what other ar radiator can fit? J_J_T Grand Prix 3 03-04-2006 10:03 PM
cracked radiator greyrealsteam Camaro Discussions 6 05-14-2005 11:20 AM
Cracked Radiator! Damn it!! Z-knowphobe 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 0 08-16-2002 09:13 AM
