Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-03-2006, 10:30 PM
TexasGypsy's Avatar
TexasGypsy TexasGypsy is offline
cracked radiator
Just got a crack in my radiator. Seems to be on a seem on the top next to the cap. Looks like at one time it had been brazed in the same spot. Trk has 167,00 on it and I believe it is the org radiator. Other than this trk runs great. Got any ideas? Any help would be wonderful!
Old 06-03-2006, 10:47 PM
Ramblin Fever Ramblin Fever is offline
Re: cracked radiator
Can't remember, can you fill us in on year and engine?
Fix it right by just replacing it, don't allow that engine to overheat, and for the sake of avoiding other damages, do NOT use any kind of stop leak products.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 06-04-2006, 09:40 AM
amigo-2k amigo-2k is offline
Isuzu Guy
I would order a rad from radiator.com and just replace it (167k is a lot for a rad).
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 06-04-2006, 10:03 AM
TexasGypsy's Avatar
Thanks for your replys and the links. I was thinking about just getting a new radiator but was wondering if there was another op.
Old 06-04-2006, 01:47 PM
surferfletch surferfletch is offline
I replaced mine with a Modine from NAPA. Pretty straightforward swap out.
Old 06-04-2006, 10:23 PM
directory's Avatar
directory directory is offline
would it help any to go with a bigger radiator--like as big as will fit--with slight modification to mounts, etc...
i'd think that as long as the hose placements are correct--it would be pretty simple, right?
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 06-04-2006, 11:51 PM
Isuzu Guy
you could get one that has more passes of the tube that is no bigger then you already have. Only needed if you tow hard or wheel hard.
-Ryan
Isuzu Moderator
Car Show Tips
Old 07-17-2006, 06:27 PM
radrobbie radrobbie is offline
i recently got a radiator for my 93 rodeo from a parts recycler. $70 instead of $150 online. I checked it out real good for cracks or evidence of leak stop, had none so i bought it and installed it. The radiator works great, no leaks and has brought the engine temp down.
