Old 11-20-2010, 09:38 PM
jalopyjoe jalopyjoe is offline
Water getting into headlights
I'm not sure if only I'm having this problem, but for some reason, water is getting into my headlights every time it rains. I don't even have to drive it, it just has to sit in it. It got to the point where it filled it half way on one side and blew out the bulb.
I tried using aquarium glue to seal the outside front edges of the assembly, it got better. So I tried sealing the back edges. It got even better. But moisture still is getting into it. Anyone having the same problem? It's a 98' S-10 4x4. Any suggestions to fix this?
I can't spend for a new set of headlamps right now if that's what is going to be suggested.
Thanks
98' S-10 4x4- Nice Truck
92' Previa
Now a 99' Camry
Old 11-21-2010, 01:58 AM
viggy58 viggy58 is offline
Re: Water getting into headlights
other than replacement, i'd suggest sealing the back, where the bulb actually screws in the housing. maybe use silicon, or something that you can easily remove in case replacement is necessary.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 11-21-2010, 08:58 AM
ctwright ctwright is offline
I would try to drill a small hole somewhere in the bottom of each.
Old 11-22-2010, 12:48 AM
I like ctwright's idea. I will try that & see what happens. I'll let you know.
Thanks
92' Previa
Now a 99' Camry
Which maxima did I get wismo Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 11-21-2010 01:04 AM
