Old 11-20-2010, 06:18 PM
jrsbmws jrsbmws is offline
77 f250 brake trouble
Front brakes wont release,have replaced master cyl,hoses, caliper seals.
Old 11-20-2010, 06:51 PM
ctwright ctwright is offline
Re: 77 f250 brake trouble
you might have to replace the caliper(s), the piston(s) might be locked up.
Old 11-20-2010, 07:02 PM
after posting that I noticed you said you replaced the seals, I guess you would have notice then whether or not the pistons were locked up and I'm sure they weren't in order for you to replace the seals, I don't know what it could be after looking at that, how does the brake pedal do? does it come back up?
Old 11-26-2010, 12:14 AM
4x4 blazerguy 4x4 blazerguy is offline
Is the proportioning valve centered?
Old 11-26-2010, 07:27 AM
big white bufflo big white bufflo is offline
are the calipers free floating on the slides make sure you have the spring on the correct side of the wedge and antisize them so they move and try to push them back with a c clamp i have seen these piston go in crooket it will help them seat in
02 Blazer DIY Brake Job Advice Brndo Blazer 6 03-13-2011 09:35 AM
F250 Brakes AndreD F Series 2 05-06-2010 01:19 PM
brake troubles dfarres Accord/TSX/Accord Hybrid 12 09-03-2004 01:01 PM
brake trouble beastfromeast Accord/TSX/Accord Hybrid 4 02-28-2002 10:48 AM
Brake trouble beastfromeast Engineering/ Technical 5 02-27-2002 08:28 PM
