Old 11-19-2010, 10:26 AM
pontiacfanactic pontiacfanactic is offline
1991 lesabre chugging and stalling when run hot
Please help. 1991 Lesabre 3800 with 320,000 miles stalls and won't run good after driving 12 miles on freeway. Used scan tool due to CEL coming on after symtoms arise. Received Problem ID 2504 Trouble code 42 and coses 56 55 54 53. Replaced Fuel pump relay. Drained and flushed coolant and installed a new thermostat. Unhooked ground cable each time I did repair and symptoms still reappear along with the same codes. Searched posts and saw something like EDR and PCM could be related to codes. My scanner reads codes as follows 56= Corrositivty add col 55= ECM ADV Error. 54= Fuel pump relay. 53= Over voltage.Any ideas as sesors and controls are still expensive and I am baffled why it will run good on road test. Then performance will again decline. Scan tool is a Matco 4000. Are codes related to one thing being wrong . Thanks in advance for any help.
Old 11-19-2010, 10:59 AM
Scrapper Scrapper is offline
AF Premium User
Re: 1991 lesabre chugging and stalling when run hot
run it by autozone have them hook it up it's free. sounds to me like coils are getting hot. check the spark if blue there good coil if yellow not good may be coil pack problem. those 3.8 or 3800 is same thing and good engines.
Old 11-19-2010, 01:32 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Code 42 indicates that the Electronic Spark Timing (EST) signal did not change when the ECM applied bypass voltage to the ignition module. Check for faulty connections, or a faulty ignition module.
Old 11-22-2010, 02:47 PM
CAMFLIGHTRN CAMFLIGHTRN is offline
I agree with scrapper,
Check or replace the coil packs. I had similar symptoms and the coil packs check out fine when cold and ohm checked out also within specifications. After the engine was warmed up I rechecked the coil packs and found one to be defective on one side. $28 at Autozone and good as new.
Old 03-21-2011, 12:36 PM
Relaced the coil the ignition control module underneath it. The spark plugs and wiress. Same codes reappear as before. Could this be it need a brain box or what most call a computer (ECM)? The car will run after short disconnection of battery but will stall and have CEL flicker and tick repeatedly along with other red idiot light on the dash. Are these symptoms of a bad computer is there a test for the computer to prove that it is the problem?
Old 03-21-2011, 07:10 PM
AF Premium User
you might try a new pigtail that go's to you alt. there not very much if that's not it i would say computer.
Old 03-22-2011, 11:13 AM
I did order a computer and will install tomorrow as I saw in other posts that it will show faulty fuel relay and is a common problem. Will post if it solves issue. Love this forumn. Couldn't do it without you guys. Thanks
Old 03-31-2011, 11:59 AM
Has run well since replacement of computer. Solved all issues. After installing computer you have to run it with a/c on for five minutes then for five minutes while in drive with wheels blocked then five minutes driving. Has worked thus far. Thanks
Old 04-24-2011, 05:44 PM
BuickLeSabre91 BuickLeSabre91 is offline
Hey i have a 91 LeSabre custom and its used to stall a bit at start idle and when acceleration, it seems a bit better now, but its still not very good, my coils arent good i think. the blue stuff leaked within it but not on the outside. but i have benn told its the fuel pump?
93 lesabre runs rough and stalling pigeonkiller LeSabre 4 01-10-2010 06:30 PM
'97 Lumina stumbles and stalls when hot Luminiac Lumina 7 11-02-2008 11:18 PM
1993 lesabre spudders loses acceleration and stalls when less than a half tank of gas phhauk LeSabre 6 04-08-2005 08:53 PM
Runs loud and sluggish when warm/hot. 350 shakesnow Blazer 0 07-21-2004 03:25 PM
92 chevy lumina runs rough and stalls when brakes are applied Tater_Salad Lumina 13 02-21-2004 09:27 PM
