Old 04-05-2005, 07:31 PM
phhauk phhauk is offline
1993 lesabre spudders loses acceleration and stalls when less than a half tank of gas
Has anyone ever heard of this problem. I thought that this could be the feul pump but a mechanic told me taht the pressure was good. If the car has a full tank no problems it runs fine. Less than half tank and it starts to lose power, run poorly and stall when stopping.
Any ideas?
Pete....
Old 04-07-2005, 05:45 AM
yogi_123rd yogi_123rd is offline
Re: 1993 lesabre spudders loses acceleration and stalls when less than a half tank of gas
Water in the gas?
Old 04-07-2005, 09:22 AM
LeBuick's Avatar
LeBuick LeBuick is offline
My 92 Bonneville had this problem, turned out there is a plastic resevoir in the gas tank. Not sure exactly what its purpose is but it was cracked and caused this problem. Had to bbuy a new tank which wasn't cheap.
Old 04-07-2005, 11:15 AM
93buicklesabrelmtd's Avatar
93buicklesabrelmtd 93buicklesabrelmtd is offline
Fuel Pump Strainer!
My 93 limited did that when it was on quater tank. Also when I made sharp right turns like coming of the exit ramps. The problem was easliy fixed by droping the gas tank, then replacing the FUEL STRAINER. This is mounted directly bellow the fuel pump. Everyone told me it was the pump, but I knew it was not. It would pump hard when I was turning left. The new Fuel Pumper strainer was like 17 $ . Car runs great now.
I would replace the strainer before the pump.
Old 04-07-2005, 03:40 PM
Re: Fuel Pump Strainer!
Thanks very much for the top and information. I will check into this strainer. Pete....
Old 04-07-2005, 10:31 PM
LeBuick's Avatar
Re: Re: Fuel Pump Strainer!
Make sure to look at that plastic deal while you are in the tank...
Old 04-08-2005, 08:53 PM
Re: Re: Re: Fuel Pump Strainer!
Thanks it turned out to be the fuel pump $230.00 and strainer. Plus new straps 18.00 for the set.
