Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 11-18-2010, 10:02 PM
Dave884x4 Dave884x4 is offline
Ignition Cylinder issue
Someone tried to steal my Tahoe, thank god they failed but they screwed up some stuff. Truck ran fine before, no problems at all. I had to replace the ignition cylinder, and it wont stay running, it acts like it wants to start but dies a second later. There was a small sensor on top of the lock cylinder housing with 3 wires that was broke out, it didn't look messed up bad, so i tried to put it back on, would that sensor cause no start, what the hell is it anyway. oh and the illuminated gear indicator on the gauge cluster stays on with the key off. Any and all ideas welcome, I will try anything, I need to get this truck running, thanks.here are some pics of the three wire sensor.P1030285.jpg
Old 11-18-2010, 10:17 PM
Obysk Obysk is offline
Re: Ignition Cylinder issue
This may be a security system problem.
Does the truck start up normally and then stall a second later?
Do you have a "Security" or "Theft" light that stays on (may be blinking) after the truck stalls?
If so try this, attempt to start the truck and let it stall but DO NOT turn the key back off. Instead wait to see if the security light goes out (this may take 10 minutes or so) and if it does turn the key off and then attempt another start.
Without seeing the truck or knowing exactly what is happening this is the best advice I can give right now. Try it and let us know.
Old 11-20-2010, 07:43 AM
j cAT j cAT is offline
Originally Posted by Dave884x4 View Post
Someone tried to steal my Tahoe, thank god they failed but they screwed up some stuff. Truck ran fine before, no problems at all. I had to replace the ignition cylinder, and it wont stay running, it acts like it wants to start but dies a second later. There was a small sensor on top of the lock cylinder housing with 3 wires that was broke out, it didn't look messed up bad, so i tried to put it back on, would that sensor cause no start, what the hell is it anyway. oh and the illuminated gear indicator on the gauge cluster stays on with the key off. Any and all ideas welcome, I will try anything, I need to get this truck running, thanks.here are some pics of the three wire sensor.Attachment 41024
Attachment 41025
the ignition key has a device that the ignition cylinder lock sensor must communicate with . the engine will start then quickly die with the security system messed up.
the shift indicator light maybe a part of this sercuity issue.
when the vehicle is turned off for a time this is slightly lit. then after a short period of time goes out..seems to be the same time the security light stops flashing..
96 S10 Ignition/Starting Issue fmhsgrad96 Problem Diagnosis 5 05-25-2012 08:19 PM
Ignition switch problem or ignition cylinder problem? winsett Accord/TSX/Accord Hybrid 5 02-17-2010 11:52 AM
Ignition Lock Cylinder & Worn Keys... Intuit Escort 2 02-18-2009 09:51 AM
190e ignition cylinder lock removal? babella E-Class 0 03-12-2003 11:12 AM
