Old 11-18-2010, 06:23 PM
Rottweiler482 Rottweiler482 is offline
Miss fire when climing hill
I have a 2002 4.3l 4 dr S-10 with automatic trans.
Every time i go up a steep hill my service engine light flashes, according to the manual that means there is a miss fire.
It only happends when going up a hill for a while then stops and comes back on again.
What would make this happen does anyone have any idea..
I have replaced plugs, wires also put new fuel pump, and filter..
any suggestions would be helpfull.
Old 11-18-2010, 09:45 PM
jdl jdl is offline
Re: Miss fire when climing hill
Does the tranny have overdrive? If you downshift, does the problem go away? Any applicable trouble codes?
Old 11-19-2010, 06:00 PM
yes the tranny does have over drive, even when it is taken out of od it still does it.
it comes up PO300 cylinder misfire comes off when i stop but as soon as i start up the hill again it comes back on
Old 11-19-2010, 09:20 PM
old_master's Avatar
Advisor/Moderator
P0300 DTC along with a flashing SES light is almost always caused by secondary ignition failures: Spark plugs, spark plug wires, distributor cap and rotor, ignition coil. Always use AC Delco plugs, cap and rotor in the 4.3L, they are very fussy. Put a dab of silicone dielectric grease on each terminal, inside and out, of the distributor cap. Post your results.
You have to know how it works,
to figure out why it doesn't.
Old 11-20-2010, 02:27 PM
mcmalloy mcmalloy is offline
could be the knock sensor
Suburban miss fires after going up a hill? 99subhelp Suburban 103 06-29-2017 03:55 PM
96 villager miss fire when hot divot91 Villager 16 12-10-2010 04:02 PM
Buick Lesabar Misses when climbing hills no engine lite LawrenceH LeSabre 3 03-28-2010 01:30 PM
miss fire when cold please help ocpman Suburban 10 01-30-2010 04:37 PM
multiple miss fireing when towing scott1500cl Sierra 2 03-20-2007 05:21 AM
