Old 11-18-2010, 12:13 PM
Woodsm Woodsm is offline
2001 T&C Leaks Gas From The Exhaust??
I have a 2001 Town and Country and when I start it up, in about a minute or so, it starts to leak gas from the exhaust. White smokes come from the exhaust and gas starts dripping out onto the ground. Do any one might know what the problem are?
Thanks,
Marion
Old 11-18-2010, 01:58 PM
inafogg inafogg is offline
Re: 2001 T&C Leaks Gas From The Exhaust??
sounnds more like a coolant leak into exhaust
why do you think its gas??
have you checked the coolant level?
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 11-18-2010, 02:45 PM
mikefaster mikefaster is offline
If it runs fine and has a "sort of" white smoke, it could be just condensation...
If it runs bad, it's a head gasket, most likely... Did you overheat it lately???
Just to let you know, take off the gas cap and take a sniff, then sniff your exhaust pipe... If they don't smell the same, then it isn't gas coming out of your tailpipe... All kidding aside, it would be evaporating before it would make it to the tailpipe exit or be a giant flamethrower, LOL...
Mike
I smelled gas and seems to be pure gas. The coolent level is good. I had the head gasket replaced but still the gas continues.
The vehicle use to run rough but since replacing the head gasket, the roughness is gone but the gas continues.
The vehicle didn't over heat. There's no water mixed with the oil.
Please continue to help!
Old 11-18-2010, 02:47 PM
Does it run well, aside of the smoke???
Old 11-18-2010, 03:12 PM
Also, did you JUST have the head gasket replaced... Like yesterday???
If you have a lot of the old antifreeze caught up in the exhaust system, it can take up to an hour to REALLY "burn" out everything from the old head gasket being blown...
Old 11-18-2010, 03:40 PM
Yes, the head gasket job was completed about two days or so ago. How ever, I also notice gas coming from the maniford (from under the hood).
The vehicle runs well.
I'm being told that I could gotten hold of some bad gas or water might be in my gas tank.
Old 11-18-2010, 04:16 PM
Water in the tank would make you run bad...
If it runs well, it may be residual antifreeze in the exhaust... May take a GOOD hour of heavy driving to remove...
If you have any gas leaking under the hood, then those people who fixed your head gasket, may have broke something else (the manifold is under the hood) and it should be fixed right away...
Gasoline is flammable and dangerous...
There really is no possible explanation to have raw gas out of the tailpipe... If anything, it would be in the form of BLACK SMOKE and the van would not run properly...
Antifreeze that is burning out of the exhaust system SMELLS REALLY BAD, but not like raw gas...
Good luck...
Old 11-18-2010, 04:29 PM
I understand. When I first noticed any thing, I noticed the strong smell of gas. It's a good thing I was at home at the time. After I restarted the vehicle, the vehicle ran rough and that's when I noticed the gas coming from the exhaust. After the head gasket was replaced, it took away the roughness but not the gas. After rubbing my hand under the manifold, that's when I noticed wetness from the manifold.
Old 11-18-2010, 04:34 PM
IF you are seeing gas leaking from manifold you may have the seal leaking
from the quick disconnect connection.not some thing you want to leave unattended
call repair shop. they may want to tow car or send someone to take a look
DO NOT DRIVE IN THIS CONDITION
Live For Today
Yesterday is gone,
Old 11-18-2010, 04:39 PM
Ditto...
Old 11-18-2010, 04:42 PM
I forgot to tell you but it's at a car repair shop now. I had it towed there when I noticed the gas smell. The car shop thinks it's gas in the tank or maybe something wrong with the computer. I'm not sure, I'm trying to get as many solutions as possible, so I can tell them to check this or that. But no, I won't drive it. I won't even take it from the car repair shop until it's fixed.
Thank you,
Old 01-19-2013, 07:45 PM
jajaadjani jajaadjani is offline
hi i know this is a pretty old topic but i am hoping you can tell me if you ever found a solution to your problem.as my car is having a similar issue after the head gasket was replaced raw fuel id leaking out the tail pipe and i haven't been able to find out what the problem is.and i am tired of people saying its impossible for it to be gasoline.
hope you can help me out
my integra is leaking gas into the motor oil help anyone?? acurky Integra 3 11-11-2004 04:32 PM
90 lumina leaking gas from throttle body cloud14 Lumina 0 07-27-2004 02:30 PM
Why? gas flood the exhaust camry 1992 v6 smallbaby Camry/Camry Hybrid/Vista 1 06-28-2004 01:04 AM
smoke from the exhaust aznracer520 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 9 06-02-2004 02:02 AM
steam coming from the exhaust on a warm day tacoma man Tacoma 2 04-19-2004 07:56 PM
