Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 06-01-2004, 08:30 PM
aznracer520 aznracer520 is offline
smoke from the exhaust
i got a 92 240sx SE. When i was driving my other car, and my friend was driving my 240sx. I saw alots of white smoke coming out. Is there any way i can fix that problem? Should i get a new cat converter, cat-back exhaust??
Anything just help me out!
Old 06-01-2004, 08:33 PM
zdude zdude is offline
Send a message via Yahoo to zdude
Re: smoke from the exhaust
ummm... if it were bluish tint, then id be worried, cuz that means your car is burning oil. white smoke may be cuz it wasnt warmed up, but i see your from virginia, so i doubt that... never seen white smoke on a warm day
RAF Mildenhall, UK
92 Paseo (Died)
90 Corolla (Died)
89 240sx (sold then died)
85 735i (Died)
95 Corolla (Damn Deer)
94 Renault Espace (gave away lol)
94 BMW 316i
97 BMW 528i
97 Blazer
[email protected]
Old 06-01-2004, 09:10 PM
it was completely white smoke, but it smell.
Old 06-01-2004, 09:17 PM
im so confuzed, any other problems withthe car?? cuz i just thought of an idea, which you wont like. cuz im thinkin head gasket maybe. i couldnt tell ya...anyone else???
RAF Mildenhall, UK
92 Paseo (Died)
90 Corolla (Died)
85 735i (Died)
94 BMW 316i
97 BMW 528i
97 Blazer
[email protected]
Old 06-01-2004, 09:59 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Re: smoke from the exhaust
white smoke is normal at hi rmpz, its most likely carbon build up burning out but heavy white smoke at idle is bad thats antifreeeze burining so its a head gasket leak, next time u start your car go and smell the smoke if is smell like anitfreeze(sweetish smell) that u got a head gasket leak..
1
Shift_BOOST
97 s14
Old 06-01-2004, 10:05 PM
i think it might be the gasket leak. Fixing that, would it be a pain? and how much would it cost to take it to a mechinal place?
Old 06-01-2004, 10:08 PM
turbo2nr's Avatar
yup head gasket fix are a pain in the ass you have to remove the head of the car which involves taking off the intake/exhaust mainfolds.. studs might brake ect.. usually cost about $400-$700 depending on machinic i dont recomend doing this your self pay and get it done right b/c u can seriously mess up your motor
1
Shift_BOOST
97 s14
Old 06-02-2004, 12:25 AM
DWF Engineering DWF Engineering is offline
My bet would be the head gasket. A compression check is the best way to check this. Take it to your mechanic and ask for a compression check, it will be cheaper than the tool to check it yourself; Autozone may perform a check for free. Its not all that hard to change the gasket yourself. I changed the gasket on my MR2 myself and was very successful. The kit from Autozone is about $150 and you'll also need the service manual from either the parts store or your Nissan dealer, a good set of wrenches and sockets, and a torque wrench if you don't think you have the feel to gauge torque by hand.
While you have the head of you should change your timing chain and re-shim your valves too. If you're into modding, now is a good time to debur your manifolds, ports, and combustion surfaces of your head as well as port matching the manifolds to the head. You can have the head milled a bit to raise your compression ratio. You'll gain about 10 hp then if you have the cash JWT sells a sport cam set for a bit over $500 that could give you another 10-15 hp.
Old 06-02-2004, 12:29 AM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
I would check the piston to wall gap and check out the bores for grooves.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 06-02-2004, 02:02 AM
stealthj's Avatar
stealthj stealthj is offline
Send a message via AIM to stealthj
headgasket? fuck that motor, time to swap
BANNED
