Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 11-17-2010, 05:01 PM
drdr05 drdr05 is offline
2005 Corolla CE chirping
There is a chirpping sound in the engine, I took it to toy and they said "it must be the idler pulley" and they replaced the water pump.
All stock
Any ideas anyone?????????
Old 11-18-2010, 10:05 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 2005 Corolla CE chirping
If they said it was the idler pulley, then why did they replace the water pump??? Go back and insist on a refund (at least the labor) since it is obvious that wasn't the problem and not even what they diagnosed it as.
Sometimes you can listen under the hood where it is coming from. Plus if you have a long stick or metal rod, you can place the end against various components (but away from the spinning and moving parts!) and listen to them closely...the chirping noise will be transmitted through the part and sound louder at the other end of the rod/stick.
If the chirping noise only happens when you accelerate, then it could be a loose accessory belt. Other likely culprits are the A/C clutch, alternator, or power steering pump...my first guess is the alternator, they tend to chirp when the shaft bearings start to go bad.
Hope this helps and let us know how it goes!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
2005 Corolla CE Power Locks ronwilliams Corolla/Matrix/Voltz 0 08-16-2009 08:33 AM
Chirp, chirp, stutter & die yes,Dear Windstar 4 01-07-2008 09:40 PM
2005 corolla or 2005 sentra blackcomet Car Buying Q&A 7 01-09-2005 06:08 PM
2005 corolla xrs vs Corolla GTS 4AGE Iggy184 Corolla/Matrix/Voltz 4 10-13-2004 08:50 PM
2005 Corolla interior question... hatchbacksi Corolla/Matrix/Voltz 3 09-20-2004 01:03 PM
