Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 11-17-2010, 03:27 PM
barnold37 barnold37 is offline
99 Durango Shifting Problem - Help
I have been dealing with this for over a year, but it seems to be getting worse. This problem mainly occurs while shifting from 2nd to 3rd, and is more intense when the engine/tranny are cold. The vehicle accelerates normally with no slipping, but when it shifts from 2nd it does not go into 3rd. I have to run the engine rpm to around 5500 (maybe a couple of times), then let it return to near idle before it shifts to 3rd. The 3 - 4 shift has the same issue, only far less intense. I don't have to run the rpm nearly as high and the shift normally occurs sooner.
Any ideas? Solenoid or servo issue? Valve body issue? Could the Lockup Solenoid cause something like this to occur?
If this is a case of front clutch leakage, how is that repaired? Total rebuild, or is it just a matter of some O-ring gaskets?
Old 11-18-2010, 11:37 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 99 Durango Shifting Problem - Help
Is your check engine light on? 1996 and up Dodge truck tranny's had problems with the governor pressure sensor on the valve body. If you have a code and it's a P1763 there's a TSB for that. Basically the PCM will have to be reflashed.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 11-22-2010, 09:27 PM
Ez Dino's Avatar
Ez Dino Ez Dino is offline
The specialist
Send a message via AIM to Ez Dino
The problem in the transmission,the direct drum is not sealing properly.transmission needs to be remove.
Old 11-23-2010, 08:55 PM
dolittle dolittle is offline
You didn't say what Eng or Trans you have but first I'd do a service and band adjustment
both rear and front. A good manual should show you how to do this.
Also check the adjustment on the throttle valve cable.
Old 12-21-2010, 03:18 PM
95redTA 95redTA is offline
Had a similar problem in myn but it was throwing a code for the transducer and solinoid replaced that and works great now
2004 Durango Many Problems Help Please face79 Durango 1 03-25-2008 05:04 PM
99 Durango Shift Problems heavyredchevy Durango 6 09-25-2006 10:48 AM
2000 T & C Shifting Problem HELP!! karenmb1234 Caravan | Voyager 1 09-07-2004 04:41 PM
1990 535i shifting problem..Help.. igotboostdou 5 Series 0 04-03-2004 09:59 PM
2000 Durango Accelerator problems/Help!! martin75 Durango 2 02-02-2004 08:12 PM
