Old 11-17-2010, 06:08 AM
tron1989 tron1989 is offline
transmision question
The torque converter in my 2001 2500HD will not always lock up once in overdrive. Especially at highway speeds. At highway speeds the torque converter lock in for about 20 seconds and right back out again and the cycle continues while driving. During city driving it locks in usually at 45 mph. But if I am onthe accelerator hard it take longer for it to lock up. The transmission shop could not find anything wrong, but did note the condition. There are no codes fromthe computer.
Old 11-17-2010, 07:57 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: transmision question
Could also be a engine running problem.
Get it on a good engine transmission capable scanner and check both engine and transmission.
Is the engine running at full power?
Engine has to be running good for transmission to work right.
Let us know what you find on engine running.
MT
Old 11-17-2010, 08:17 AM
j cAT j cAT is offline
If the vehicle has no drive train DTC or engine DTC if you lucky the maf maybe dirty.. this can mess up the transmission shift operation. the other item may be the brake switch . when hitting the brakes the lock up cuts out.
use CRC MAF cleaner only and follow the directions on cleaning the MAF..
If you see no changes could be worn transmission componets.
Old 11-17-2010, 10:27 AM
Thanks
Old 11-17-2010, 06:23 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Wheres the transman when you need him,
Idk if the 4l80 is the same as the 60 when it comes to the tcc solenoid and valve setup but they have been known to wear out. There are updated parts available for these.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 11-17-2010, 08:32 PM
transman618 transman618 is offline
Did they monitor the TPS?? This is the most common problem with TCC's falling in and out of lockup. It doesnt have to set a code, all it needs is a brief spike which is usually caused by a faulty TPS or from electrical noise from the alternator. The shop needs to drive the vehicle with a scanner attached and monitor TPS and TCC activity.
transman
GM MASTER TECHNICIAN
SR. TRANSMISSION BUILDER
Old 11-17-2010, 11:35 PM
kahjdh's Avatar
There he is!
This guy knows what he is talking about.
Current Cars:
Past Cars:
Old 11-18-2010, 06:25 AM
Thanks
97 GA wiring question/ Tranny question BlackZodiac Grand AM 4 11-03-2008 08:40 PM
Questions! ...Lots of Questions! ...Tune up time again...Nuts! 1999montana Montana/Montana SV6 10 10-24-2008 12:43 PM
700r4 transmision question Tims_240 Camaro Discussions 9 03-05-2007 12:01 PM
Transmision question memo27 Impala | Impala SS 23 04-20-2005 07:03 AM
