Old 03-03-2007, 11:18 PM
Tims_240's Avatar
Tims_240 Tims_240 is offline
700r4 transmision question
I want to know if I can put a manual spline shaft in my s10 1993 2.8L 700r4 transmission to make it mate with my 1988 tpi 350 camaro engine.
thanks
mods list: t3/t04e, iap oil lines, iap i-c piping, xspower i-c, z32 mafs, enthalpy tuned ecu, 615cc injectors, s14 tomei fuel pump, blitz DD bov, tial 38mm w/g, BD exhuast mani./downpipe, Spec StageIII clutch .
.s13 power.
power estimate at ~ 270 whp @ 11 psi.
Old 03-04-2007, 01:13 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: 700r4 transmision question
nope
Old 03-04-2007, 01:37 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
bolt patterns on the bellhousings are also different
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 03-04-2007, 01:52 AM
Tims_240's Avatar
damn that sucks...
do you guys have any suggestions on how to make this work, I basically want to put my 350 tpi motor from my '88 camaro in my 1993 sonoma s10.
thanks again.
.s13 power.
Old 03-04-2007, 09:57 AM
1986Z28's Avatar
Has a Camaro
get a used v8 trnny, you needs bigger rad, motor mounts, headers, lots of shit, im helping a friends put a V8 in a sonoma right now
Old 03-04-2007, 10:24 AM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
there are some companies that make bellhousing adapters to make different combinations work. but even if you could get the mated together, that engine will eat that tranny alive in no time.
again, find a used 700R4 from something that had a V8. you'll know it came from a V8 because the tranny-to-engine (bellhousing) bolt locations are farther apart.
what happened to the 700r4 your '88 tpi had?
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 03-04-2007, 11:22 PM
Tims_240's Avatar
see thats the thing.. i want it to be manual, i have the auto in my 88 camaro right now..
so blown boy.. how much progress have you made so far in putting that in..
from what i understand i will need to purchase a manual tranny for a 350, now the sonoma is a manual so i wont need to install a clutch pedal or anything, what else will i need, will the motor mounts on the 350 bolt onto the sonoma crossmember? and will i need to get a custom driveshaft? thanks guys..
-tim
.s13 power.
Old 03-05-2007, 09:40 AM
Blue Bowtie's Avatar
Registered Offender
The other consideration is that the forward clutch and 3-4 clutch (already a weak point) likely have fewer clutch plates and steels, and a use spacer in the stack. This means less torque throughput before slippage and damage occurs. Using a V-6 trans behind a V-8 without some rework is risky.
Old 03-05-2007, 01:00 PM
1986Z28's Avatar
Has a Camaro
so you want a manual in the s10 tiwth the 350 tpi, if so youll need another bellhousing and other shit, if its just the auto, then just find a used V8 700R4(there easy to find for like 150$)
you will need headers, these are the ones we are running
http://store.summitracing.com/partde...5&autoview=sku
stock V8 motor mounts are in the wrong place to bolt up to the S10 crossmember like these which are what we are using
http://store.summitracing.com/partde...?part=TRD-9906
if your keeping the TPI you need to swap the comp and wiring, bigger rad(mid 80's vette aluminum is what we are going to use)
since the s10 usually comes with a 700R4 driveshaft i beleive will be fine, but dont hold me to it
also need another fuel pump most likely for the tpi, most people think it a easy swaap, but the is ALOT involved
Old 03-05-2007, 01:01 PM
1986Z28's Avatar
Has a Camaro
also id find a v8 t5(im pretty sure that what you will have)
