Old 11-16-2010, 03:42 PM
RidingOnRailz's Avatar
RidingOnRailz RidingOnRailz is offline
Cool All-In-One Service Centers
Yknow the ones, Valvoline, Jiffy-Lube, etc.
I debate this with them all the time, but why, why, why must they top off my fluids so that when I check them I spill all over the engine bay??
Pwr Steering, for instance on my car there are 4 important levels, from the bottom up: Min Cold, Max Cold, Min Hot Max Hot. I visually check it in the shop after they service my car, and forget "Hot Max" - I cannot even see the top of the fluid until I remove the cap and spill some fluid on the power steering line and the engine block!
Engine Oil: It's never filled to just within the cross-hatch/grid on the stick! It's waaay above that, and this is room temperature shop oil, not the hot old oil I just drove in with for service.
All in all, they insist these fluids are filled correctly, and that I should consult my owner's manual. WTH? I checked the manual and it simply confirms the markings on the stick or canister under the hood.
Where's the disconnect here, folks?
Old 11-16-2010, 03:54 PM
betuaintgotthis betuaintgotthis is offline
Re: All-In-One Service Centers
Dont know what they are playing at with the power steering its not really that difficult to top up. But imagine they have a computer that says your car takes x amount of oil so they stick that in. Unknown to them it is actually supposed to take y amount of oil. I personally would say that it should be just below maximum when cold.
Old 11-16-2010, 09:18 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Being a Jiffy Lube employee requires a piss test and watching a 15 minute video. Not kidding. Going to Jiffy Lube to have any service done is like going to Freshman Pre-med major to get brain surgery.
Just don't.
Dragging people kicking and screaming into the enlightenment.
Old 11-16-2010, 09:22 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
There's about a zillion stories of bad service out there from shops like these.
IMO your local store probably has a manager with some quirks or shortcuts, and teaches all the employees his bad habits.
My dad used to go to one of these places for years, They never tightened-up the oil filter to spec. It was always a bit 'loose', imo so they could unscrew it more easily in 3 months time. I always had to snug it up a bit.
All in one place dash kit made in USA gotrim General Discussion 0 02-26-2009 04:52 AM
raise and lower...ALL IN ONE! lincolnmaster80 Expedition 0 02-15-2006 12:26 PM
all-in-one signal switch.... 1998 Jimmy bigbadbowtie Jimmy 1 03-21-2005 09:36 AM
Tags
engine , fluid
