Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-16-2010, 12:15 PM
quickdeath quickdeath is offline
Transmission stuck in gear. ...and then not
Last night I went to put my car in reverse, and with the clutch all the way to the
floor it stalled it. I tried to put it back in neutral to restart it, and the shifter wouldn't budge. I tried bleeding the clutch, thinking maybe it wasn't moving the push rod far enough to take it out of gear, and while I did have a little air come out, after maybe a dozen times of bleeding it, it still wouldn't go out of reverse.
After maybe an hour and a half of fiddling with it in the cold, I decided to just have it towed, and planned to look at it today. By the time the tow truck showed up (almost five hours after I got stuck there..) magically it decided to let me shift it back to neutral without the least bit of fight.
What could be causing this? I'm at a loss..
1991 Mitsubishi Eclipse 2.0l T
Clutch pedal assembly was rebuilt by shepracing @ 1 1/2 years ago.
also at the same time I replaced clutch master and slave, as well as installing
an ACT 2600 pressure plate with street disc, clutch fork, and throwout bearing.
I should also note that my second and third gears have been grinding for at least a year now. If there is any more information I can provide that would help find a
solution to this problem, let me know.
'91 Eclipse, 2.0l turbo
Old 11-17-2010, 06:41 AM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Transmission stuck in gear. ...and then not
The only thing I can think of is if something is stopping the shifter itself from moving. Is something in the center counsel that is not allowing the shift lever to move? It would take much to stop it. Or is something under the hood near the shift levers that could be stopping the movement. Unless something is messed up inside the tranny.
Old 11-18-2010, 12:40 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
With the motor off you should be able to switch threw all of the gear without the clutch. With it stuck in reverse did you try and restart it with the pedal all the way down? Did the car move backwards? If so the clutch is not fully releasing.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-22-2010, 12:01 PM
Well, I was finally able to tear into it this weekend. I ended up finding a piece of the clutch disc's hub, about two inches long, broken off and sitting in between it and the pressure plate. Hopefully this was the only thing wrong with it this time.
Old 11-22-2010, 10:32 PM
Holset powered 420a
damn that sucks, hope you get it fixed
98 Eclipse GS Turbo
2001 BMW 325i - DD
All ash lights on, transmission stuck in low Dadof4STL Let's get Technical! 0 04-02-2010 09:51 AM
Transmission slipped out and will not go back in! Bulldog Brewer Ranger | Courier 1 02-17-2007 02:00 AM
Out of gear/Transmission until shutoff and then, restart the engine ARJUNBEER Windstar 1 09-12-2005 11:03 PM
