I have a 2001 Isuzu Rodeo with a blinking red light on the left side of the steering wheel. I've been told the light indicates the alarm still works, but when I test it, the alarm does not sound off. Someone suggested I reprogam the car alarm, but I have only found program codes for the fob/keyless entry remote. All of the Isuzu dealerships in my metroplex have closed down since Isuzu went bankrupt. Any ideas on how to get the car alarm for a 2001 Isuzu Rodeo working, again? I think I need the program code, but I'm not sure. Please help!
Re: 2001 Isuzu Rodeo Car Alarm Program Code
I had the same problem... no fob for the alarm when i bought my truck. , so had to buy one ...the instructions work, but took me a few tries .. do it exactly as stated. just follow it to a T...be sure you have a good battery in your key fob
![]() AMIGO 1998-2000, AXIOM 2001-2002, RODEO 1998-2002,RODEO SPORT 2001-2002,TROOPER 1998-2002 PROGRAMMING INSTRUCTIONS (1) THIS PROCEDURE ERASES ALL PREVIOUSLY PROGRAMMED REMOTES. (2) OPEN DRIVERS DOOR (3) INSERT KEY IN IGNITION SWITCH. (4) WITHIN 5 SECONDS TURN IGNITION SWITCH TO ACC THEN OFF 3 TIMES IN 5 SECONDS. (5) WITHIN 10 SECONDS CLOSE AND OPEN DRIVERS DOOR TWICE. (6)WITHIN 10 SECONDS TURN IGNITION SWITCH TO ACC THEN OFF 5 TIMES. (7) CLOSE AND OPEN DRIVERS DOOR. DOORS SHOULD LOCK AND UNLOCK. (8)WITHIN 20 SECONDS PRESS THE LOCK OR UNLOCK BUTTON ON THE REMOTE. DOORS SHOULD LOCK AND UNLOCK. (9)WITHIN 20 SECONDS PRESS LOCK OR UNLOCK ON THE REMOTE. DOORS SHOULD LOCK AND UNLOCK. (10) NOTE: IF DOORS LOCK THEN UNLOCK 3 TIMES PROGRAMMING HAS NOT BEEN COMPLETED REPEAT ABOVE PROCEDURE. (ADDITIONAL TRANSMITTERS) (1)OPEN DRIVERS DOOR (2) INSERT KEY IN IGNITION SWITCH WITHIN 5 SECONDS TURN IGNITION SWITCH TO ACC THEN OFF 3 TIMES IN 5 SECONDS. (3) WITHIN 10 SECONDS CLOSE AND OPEN THE DRIVERS DOOR TWICE. (4) WITHIN 10 SECONDS TURN IGNITION SWITCH TO ACC THEN OFF 3 TIMES (5) CLOSE AND OPEN DRIVERS DOOR. (6)DOORS SHOULD LOCK AND UNLOCK. WITHIN 20 SECONDS PRESS LOCK OR UNLOCK BUTTON ON THE REMOTE. (7) DOORS SHOULD LOCK AND UNLOCK. (8)WITHIN 20 SECONDS PRESS LOCK OR UNLOCK BUTTON ON THE REMOTE. DOORS SHOULD LOCK AND UNLOCK.
2001 Rodeo LS (mine) 2000 Rodeo LS (hers) 1995 Rodeo (sold) |
