Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 11-15-2010, 01:14 PM
tommy3678 tommy3678 is offline
List of Repairs...which one(s) to do?
Hello,
I have an '01 SS with just under 170k on it. I need it to last to Feb of 11. Below is a list of repairs my shop has just informed me about, but I don't think I need to do them all. Which ones would you do?
  1. fuel pressure regulator (leaks)
  2. vacuum connector on regulator cracked
  3. leak on top of exhaust resonator
  4. cv boot leak drivers side (I caught this because grease is sprayed)
  5. tie rod end (drivers side, 1/2" of play)
The fuel pressure reg is giving me a hard start, so I will fix that. Vacuum connector I might have to get from dealer but should be easy/cheap hopefully.
Resonator I can probably ignore, hey?
What about the CV boot and tie rod end?
Thanks!
Old 11-15-2010, 07:35 PM
maxwedge maxwedge is offline
A990 racer
Re: List of Repairs...which one(s) to do?
Tier rod is a safety issue fix this for sure, the boot/axle should hold up but if you hear clicking on sharp turns, axle failure is imminent.
Old 11-15-2010, 09:56 PM
Thanks for the input!
I had the shop do the tie rod end because then he could line everything up where I probably couldn't in my garage.
Ordered the vacuum tube from the dealer, $28 bucks, and I'll pick up a fuel PR tomorrow for $46. I won't worry about the exhaust, but I'll take it in to CV Pros here in Madison. $99 bucks for boots in an hour.
What Beetle do i have adamchrissy Type 1 12 08-20-2013 03:53 PM
Ford Taurus Transmission Repair - Rebuild Or Reman? Which Is Cheaper And Which Will Mithridates Taurus | Taurus Wagon 8 02-08-2010 04:33 PM
Yay porting! Carbide burs, which one(s)? Thor06 Engine, Transmission and Drivetrain 5 05-25-2006 10:45 AM
List of things to do with your life Cyprus106 COMPLETELY off-topic 59 02-25-2006 12:32 AM
