Old 11-15-2010, 10:05 AM
iamhelpfull iamhelpfull is offline
Knocking F150
I have a 2000 F150 automatic , V-6 with about 180,000 miles...it sounds like the valves are knocking, no real rhyme or reason as to when I hear this...even with High Test gas, but doesn't seem as bad. I've replaced the plugs with top of the line platinum and new wires but knocking started back after about 10 miles. Brought it back to the shop and found #2 cylinder plug was fouled out. Mainly hear it when starting off, but if I get on it, there is no problem or knocking. I change the oil every 5,000 with synthetic. Several mechanics have looked at it, but no solid conclusions...dang, I'm about to pull my hair out. Can anyone help me?
Old 11-16-2010, 09:42 AM
jyount jyount is offline
Re: Knocking F150
Any smoke in the mornings or disappearing coolant? Sure sounds like a leaky intake gasket has very slightly bent a rod. Had it compression tested? Even if it is a minute bit it will show low on that cylinder.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 11-16-2010, 09:47 AM
Re: Knocking F150
No, no smoke and no noticeable loss of radiator fluid...but that's the most promising thought so far. Going to go see if I can get that checked today. Thanks,
Richard
97 F150 4.2 Roaring PLEASE HELP stanley24538 F Series 7 10-25-2010 08:46 PM
f150 4.6 overheating JoeB64 F Series 3 02-06-2010 10:29 PM
1990 Ford F150 - Flooding? mizshadow420 F Series 1 02-04-2010 09:03 PM
f150 aod shifting problem barshowfamily F Series 2 11-30-2009 09:57 PM
1998 Mustang V6 engine knocks and runs rough birdstash Mustang Problem Diagnosis 2 06-04-2009 10:59 PM
