Old 11-14-2010, 06:08 PM
glennRZRS glennRZRS is offline
won't run same as eveybody else
hows it going nice site read several of the post and spent alot of money and car still does not start so here we go its a 1999 oldsmobile intrigue 3.5l 130796 miles was given to me for a hundred dollars i heard it run a year ago, ran like it was full of pressure inside the motor, no power almost like a diesel sound car sat around for 6 months friend put in new plugs wires (boots) crankshaft sensor still ran like crap checked compression all the same can't remember what it was over 100 car sat for another few months now i have it, will not even start now pulled injector rail off back 3 cylinders to check for fuel and those three cyl. tried to fire, switched the coil packs from front to back and the same three cyl. tried to fire wihout injectors down in ports ,seem to have spark and fuel but won't run drained the gas put new gas in,changed the camshaft sensor and the ignition lock clyinder car won't even fire still ,went threw the 30 minute learning process with the new key. totally lost only thing i believe left is the computer no codes are in system they were cleared before i got the car looking for something i did wrong or haven;t done yet thanks glenn
Old 11-14-2010, 06:38 PM
pfofit pfofit is offline
Re: won't run same as eveybody else
-----I gave up reading and trying to decipher this mishmash massive run on sentence after the third line.
Good luck.
If it was easy, then anyone could do it.
Old 11-14-2010, 07:12 PM
inafogg inafogg is offline
could drop the exhaust ..might be a bad cat.converter
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 11-14-2010, 07:57 PM
gutted the catalitic converter, sorry about the large sentence
Old 11-15-2010, 12:01 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Have you bothered to check the fuel pressure with an actual gauge and such? If so what sort of numbers are you getting?
The only other thing that comes to mind is ignition timing terribly off....but im not sure how these engines are timed exactly...Im sure a mechanical base time with the timing chain, and then advance/retard via computer.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 12-06-2010, 11:16 AM
fuel pressure was good thanks
broken pin on one of the cams to the sprocket, out of time car fixed
Old 12-06-2010, 11:36 AM
krivasauto krivasauto is offline
Banned
It's all about the fundamentals.
Old 12-06-2010, 11:43 AM
maxwedge maxwedge is offline
A990 racer
Thumbs up Re: won't run same as eveybody else
Originally Posted by krivasauto View Post
it's all about the fundamentals.
amen!
2000 Crown Interceptor won't start fuel pump won't run chrisstag Crown Victoria 16 01-30-2007 04:00 AM
What do you think of E85? I won't run anything else. AWDriver Engineering/ Technical 1 01-09-2006 09:53 PM
the engine runs but nothing else works!! mnt Trans Sport 3 05-15-2005 01:35 PM
Help! it won't run right Cressida Jon Cressida 1 12-18-2002 06:48 PM
audi 100 won't run off idle Scanner Engineering/ Technical 2 07-29-2002 07:35 AM
