Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 11-14-2010, 02:29 PM
Paul Buxe's Avatar
Paul Buxe Paul Buxe is offline
LS2 engine swap wont start - help
So i have finished the LS2 engine swap after 8 months of work I can't gt any spark and the engine wnt start. I have an LS2 motor out of a ’06 Corvette with a 58 tooth reluctor wheel . I have a Holley 750 carb set up so I had to add the 58 tooth MSD carb ignition system to make the switch over from FI. Anyway, the car won’t start. I checked and am getting 12 volts to the MSD box, an getting 12 volts to the coil packs (which I got used on the forum, could be an issue), but I get no spark at the plugs. So any ideas? What resistance should I read on the crank sensor, the cam sensor and the coil packs? I’m thinking that is the only thing that could go wrong. The crank sensor is new from GM, the cam sensor came with the engine. I am told the jumper cable to the cam sensor needs to be deleted for the MSD box to work right, because it seems to reverse the wires to and from the connector and have tried to start the car with and without the jumper wire, but didn’t make any difference.
Any ideas?
Paul Buxe
Panoz GTRO-0042 LS2 gone but not forgotten
Miata Chump Car
Mustang GT
Porsche Boxter (wife's ride)
Chev Suburban trailer hauler
Factory 5 Cobra Roadster, 392 stroker
You have to grow older, but you don't have to grow up
Old 11-14-2010, 02:43 PM
eric1h eric1h is offline
Re: LS2 engine swap wont start - help
Che k the crank sensor, cools also be a bas crank sensor.... I've seen that happen on used motors... If it were the. Cam sensor it would at least sputter and try to start, but if the crank sensor is bad the car won't even get any spark.... Do you have a timing pill in the msd? It won't start unless it has one in for the first start.....
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 11-14-2010, 02:44 PM
Also try hooking up the serial cable to the msd box and check to see what it sees it should at least show a signal from the various sensors... And it will confirm the msd is powered on and working
Old 11-14-2010, 07:39 PM
Panoz26's Avatar
Panoz26 Panoz26 is offline
Paul - what MSD are you using? Mine was plug in play, meaning, I did not have to delete anything... I find that odd. 6012 unit.
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Old 11-14-2010, 08:10 PM
Yeah what jumper?
Should be 5 wires...
Power, ground, pink power, cam, and crank sensors......
And make sure you have chip in.
Old 11-14-2010, 09:19 PM
Paul Buxe's Avatar
The jumper I'm talking about the the jumper cable that goes from down under the crank chaft pulley in a black curved bracket up the the cam sensor. If you look at the wires, they reverse as they make the run. A friend that put an LS2 in his Backdraft said he had to by pass that jumper to get his engine to run. But I tried it both ways and no spark.
Paul Buxe
Miata Chump Car
Mustang GT
Old 11-15-2010, 06:44 AM
Panoz26's Avatar
Paul, double check with what Eric mentioned on the "chip" or "pill" -- ensure you have one in the MSD unit. It's been known to fool a few folks.
On the "jumper" -- in my LS3 with the MSD 6012, I did not have to do anything like that.
Old 11-15-2010, 08:44 PM
Paul Buxe's Avatar
Thanks guys.
1) yes I have a pill installed
2) the crank sensor is new from GM so I'm thinking it should be ok does anybody know a restance check?
3) the cam sensor came with the motor, so it could be bad, does anybody know a restance check?
4) I need to bring my lap top home tomorrow and do the check out you suggest, good idea.
5) I'm getting 12 volts to the coils but it looks like no triger input, could be sensors.
Thanks guys
Paul Buxe
Miata Chump Car
Mustang GT
Old 11-18-2010, 07:33 AM
Any luck?
One thing that stuck in my mind.... What crank sensor do you have? I remember reading about 2 different types of sensors... Grey and black, and you needed the correct one for the msd to work properly, I can't remember details but it's worth a little research possibly.
Old 11-18-2010, 08:17 AM
Cobrafang Cobrafang is offline
Originally Posted by Paul Buxe View Post
Thanks guys.
Thanks guys
Hit CTRL-ALT-DELETE and install a stroked SBF motor.
-Cobra (A.K.A Tom D)
Racer and Gamer
Panoz GTRA (Mystery Chassis #) (Track Toy)
2001 BMW M5 (Road Toy)
2006 F250 (Car Hauler)
2002 Odyssey (Kid Hauler)
Old 11-18-2010, 02:22 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Will it turn over? Did you open up the front of the motor to ensure it doesn't have a broken timing chain?
Old 11-18-2010, 06:41 PM
Paul Buxe's Avatar
Thanks for the ideas guys, except for the stroker FMC thought, I've had this thought a couple of times, but I'm where I am.
Yes I checked both sensors and have the correct sensor for the LS2.
Yes, I had the engine apart when installing the new cam shaft. It turns over and cranks fine on the starter, just no spark.
Tonight I will connect the lap top and see if it gives me any codes, like a dead sensor or a fried MSD.
Keep the fath.
Paul Buxe
Miata Chump Car
Mustang GT
Old 11-23-2010, 05:41 PM
Paul Buxe's Avatar
The problem is that I am not getting any spark at any of the cylinders.
To trouble shoot, I have replaced both the cam and crank sensors (gray).
I am getting 12 volts to the MSD box.
I am getting 12 volts to the coils.
I am getting 5 volts to both sensors.
I have the step retard unhooked.
I have the MAP unhooked.
When I crank the engine, with or without the spark plugs, I do not get a tachometer reading on the lap top. Engine is turning over at a good speed.
I also get a “no crank signal” on the lap top. This is why I replaced both sensors.
I am getting ~ 4.5 volts return from the cam sensor. (using a multi meter, so don’t know how good that volt value really is) back to the box.
I am getting ~1.3 volts return from the crank sensor. (using a multi meter, so don’t know how good that volt value really is) back to the box.
I am only getting ~0.05 volts to the coil packs to fire the coil from the box (using a multi meter, so don’t know how good that volt value really is)
So, I’m stumped. The box is new, but can it be bad?
What else would you suggest?
Paul Buxe
Miata Chump Car
Mustang GT
Old 11-23-2010, 07:17 PM
Panoz26's Avatar
Paul, I have not seen this addressed, so, I'll ask:
Have you checked to make sure the coilpacks are on the right way? This may sound silly, but if #1 is on #7, it could cause the car to not start.
Devin
Old 11-23-2010, 09:28 PM
Honestly, best bet would be to call msd support!
1990 cont. swapped .. wont start ZOOM FD ZOOM Continental 0 06-07-2010 03:09 PM
Car wont start ethan-erickson0015 '96-'00 Civic 3 04-24-2010 10:22 PM
97 engine swap wont start xXAnarchistXx 1st Gen 95-99 6 08-05-2009 07:46 AM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
