Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 11-12-2010, 11:58 PM
21sprint 21sprint is offline
!995 SSE Charging problem?
The car will show a charge then drop off at any time warm or cold. I have changed the alternator and it never helped so I'm sure that was a waste of money. There is one heavy red wire running to the alternator hot post to Battery and 1 small red wire that plugs into the alternator. I'm not seeing and bad wires, so is this a big problem or just maybe a ground problem? Thanks for any ideas!
Old 11-13-2010, 01:28 PM
inafogg inafogg is offline
Re: !995 SSE Charging problem?
is there 12v at the heavy red wire if not trace wire back could
be the connection at starter or fusible link
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 11-13-2010, 07:29 PM
The heavy wire is running staight to the battery and checks the same as the guage on the dash or my digital volt meter. You start the car and it might be charging 14.5 or you will hear the motor's idle drop and its running 12.10 or so. Then it idles back up and doing fine. I have changed the alternator 2 times and still the same or maybe worse. I left it at my garage Friday as I was confused to no end. I wonder how the smaller wire excites the regulator as it shows no voltage until it starts working again.
Old 11-15-2010, 05:19 PM
Talking Re: !995 SSE Charging problem?
I figured it out! Bad ECM and bought one from a salvage yard for $65 so am very happy!!
Old 11-15-2010, 10:31 PM
So when it was'nt charging you lost the 12v to the alternator??
Live For Today
Yesterday is gone,
Old 11-16-2010, 06:42 AM
The small wire that plugs in is the one that was not working all the time, the battery wire had what ever volts that battery had in it. I think the smaller wire has some resistence built into from the computor.
1992 Bonneville SSE Starting Problem zbnwr Bonneville 0 03-31-2008 06:41 PM
91 SSE radio problem essikr Bonneville 0 06-08-2007 09:03 PM
!995 pontiac bonneville problems HELP! johnvanveen General Discussion 2 11-04-2005 02:40 PM
89 SSE brake problem 89sselightning Bonneville 5 03-10-2005 06:32 AM
bonneville sse 1989 problem with charging system RAYVEN2929 Bonneville 2 01-19-2004 07:24 AM
