Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 11-06-2001, 07:59 PM
frogg's Avatar
frogg frogg is offline
Send a message via AIM to frogg
Comparison between intakes
JWT Pop Charger vs. Hotshot CAI
What is the difference between these? I keep seeing them mentioned all over the place but whats the advantage/disadvantage to each?
Are they even the same thing!??
Old 11-06-2001, 08:18 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
The are different. The Pop charger is a warm air intake. It gains more power than a standard filter because the MAF adapter has a radiused (sp?) inlet to provide better air flow. Advantage being slightly less money and you don't have to worry about sucking water into the motor.
The Cold Air intake goes all the way into the wheelwell. The filter is actually in the wheelwell. This intake will make more hp, due to resonanace tuning and by colder air going into the motor. The downside is that there is the possibility to suck up water, it is slightly more expenisve, and some people don't like the noise it produces. It can be rather loud at WOT.
Hope this helps.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 11-06-2001, 09:33 PM
frogg's Avatar
So about how much does the Hotshot CAI run?
Also, what kind of sound is it? Like a deep roar sound or what?
Old 11-07-2001, 01:14 PM
JustinP10's Avatar
I paid right around $180.00 for mine about 2 years ago. (actually here's the reciept... 2 years and 3 days to be exact!) WOW! That's a long time, I had no idea i had my intake that long. As for the sound... it's a very unique sound. If you've heard a cold air intake on a Neon, it's pretty similar to that. It has a similar type of noise to the CAI's on Honda's. But the tone is totally different, a lot deeper tone. It's pretty tough to describe it with words... Does anyone have a sound file of their car, i could upload it to a site for people to listen to if needed.
Justin McClanahan
95 G20
Old 11-07-2001, 02:25 PM
AznVirus's Avatar
AznVirus AznVirus is offline
Send a message via AIM to AznVirus
whats WOT? id go with a Hotshot CAI. heres a sound file...
"buuuhhh, burrrrrrrrrr, brrrrrrrrrrrrrrrr, bzzzzzzzzzzzzzz, bzzzzzzzzz"
1.6 - The Underdog
GA16DE-T Club!
Old 11-07-2001, 03:02 PM
JustinP10's Avatar
Wide Open Throttle.
Close, but don't forget the weird resonance sound the intake makes up near redline. (hmm.. wonder in the new intake cam will change that?)
Justin McClanahan
95 G20
What Edelbrock Intake should i go with? inforcer958 General Discussion 4 02-14-2011 07:58 AM
deos anybody knows the article of comparison between CRV 2.0 l 2x4 and x-trail 2.5 l Trisna Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 12-07-2003 07:12 PM
Comparison between 3rd gen civics and 4th gens jaredu '71-'87 Civic | CRX 2 09-30-2003 12:34 AM
Comparison between Wrx 03 and Wrx 04 JUNXR34 Impreza/9-2x/Outback Sport 6 09-01-2003 02:18 AM
Gear ratios comparison between G20 & NX2000 zykotik Engine 6 07-15-2001 07:39 PM
